03-15-2021, 06:23 PM | #1 |
Active Member
Under dash wiring
Install a B P Automotive swap harness .Now i need to wire under the dash . They don't offer anything. Any recommendation for a fuse block with dimmer relays and blinker relays Horn lights ECT. Working on 72 Blazer . Thanks Pat
03-18-2021, 02:00 PM | #2 | |
Msgt USAF Ret
Re: Under dash wiring
There are three major high current draws in the cab. So you might consider running them through relays. The ignition switch, /the light switch /and the starter solenoid. It is pretty easy to control the relays using the switches. Keep in mind that the stock harness usually works pretty well for quite a while. It is The ignition switch and the headlight switch that carry the most current with the heater switch to a lesser degree. You would need several relays and lots of control wiring for them so you would have to decide if it was worth the extra time and effort when the stock system works pretty well for a long time. The headlight relay mod is the most beneficial in my opinion and it is done mostly in the engine bay. I covered that in the FAQS thread at the top of this forum.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
03-18-2021, 04:22 PM | #3 |
Almost Satisfied
American Auto Wire
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
03-30-2021, 09:22 PM | #4 |
Active Member
Any body used a BP Automotive engine harness and a American Autowire Harness? Talked to AA today . They said they have a harness but would need to remove some wires From B P harness and use theirs. Anybody done this?? need some more assistance. Thanks
Thread Tools | |
Display Modes | |
