Old 03-22-2021, 02:11 PM   #1
Kcenderjim
Saginaw setup
I am wondering if anyone has or has seen a shifter linkage setup like this. I know they are normally mounted on the tailshaft but due to where the shifter needs to sit they mounted it this way. I'm looking for any pics that will show me what this should look like once I remove the cover. And yes I'm aware that's the speedo cable and not the linkage. The linkage is behind the cover. Thanks in advance for any help or any pics...
Kcenderjim is offline   Reply With Quote
Old 03-22-2021, 04:07 PM   #2
geezer#99
geezer#99's Avatar
Re: Saginaw setup
Looks like a normal 3 or 4 speed shifter mounted with a different bracket.
Shifter is nothing special.
They’re all similar inside.
2 or 3 arms separated by springs rotating on a centre shaft.
Check YouTube for how to rebuild a hurst shifter.
Why are you taking it apart?
geezer#99 is online now   Reply With Quote
Old 03-22-2021, 05:22 PM   #3
Kcenderjim
Re: Saginaw setup
I am having an issue with 1st and 2nd. With the engine running or not I have to play with the shifter and jam it to get it to go into 1st and 2nd. I thought it might be the synchro but I was told if it does it with the engine off that should not be the issue so I wanted to make sure that the linkage is not just binding up 1st. But I have never owned a stick shift before so I'm not really sure what I'm looking at. I have seen 4 speed setups before but never one thats that close to the side cover normally they are mounted on the tailshaft. I have tried looking on line to see what it should look like but I can not find another setup like this.
Old 03-22-2021, 05:26 PM   #4
geezer#99
geezer#99's Avatar
Re: Saginaw setup
What trans is it?
Pic of shift arms would help.
Could be linkage adjustment needed, internal problem, or clutch.
Old 03-22-2021, 07:13 PM   #5
Kcenderjim
Re: Saginaw setup
It's a saginaw 4speed. I have to take the cover off to get pics of the shift linkages. Which I will be doing but I am just trying to get a pic of what it should look like when I take it off. If I had a pic then I can compare it and the problem may just jump out on me.
Old 03-22-2021, 07:29 PM   #6
geezer#99
geezer#99's Avatar
Re: Saginaw setup
No need to take any covers off yet!
Pic of the shift rods on the side of the trans can sometimes reveal a problem.
Old 03-22-2021, 08:11 PM   #7
Kcenderjim
Re: Saginaw setup
This cover needs to come off in order to see the rods. The shifter is directly above this.
Old 03-22-2021, 08:14 PM   #8
Kcenderjim
Re: Saginaw setup
Maybe this picture will help show the placement better. It shows the tailshaft better showing that there are no rods coming from there like normal.
Old 03-22-2021, 08:58 PM   #9
geezer#99
geezer#99's Avatar
Re: Saginaw setup
Let’s try once more.
Any shifting problems are 99% of the time never internal in the shifter assembly.
Shifting problems can be the shift rods and the brackets on the trans. They’re located towards the front past the shifter in your pics.
A pic of them will help.
Another possibility is shift forks inside trans are damaged. That requires side cover removal.
Take a pic of your shift linkage.
Old 03-22-2021, 10:00 PM   #10
Kcenderjim
Re: Saginaw setup
And what I'm trying to say is there are no **** rods visible in front of the shifter. The shifter comes straight down from inside the truck and is connected to the part that changes the gears on the side cover. There are no visible rods. Where the cover is that I am explaining that needs to come off is not the side cover of the trans it's a cover that is over the section the rods normally connect to. Sorry if I sound frustrated but I know there are normally rods that connect to the side cover. This setup does not have that.
Old 03-22-2021, 10:11 PM   #11
geezer#99
geezer#99's Avatar
Re: Saginaw setup
Ok!
Let’s see what you got.
Take a pic of the whole thing.
Old 03-25-2021, 06:36 PM   #12
Kcenderjim
Re: Saginaw setup
Geezer, I hope these 2 pics show a better pic of what I have. It was the best my daughter could take while climbing under the truck.
Old 03-25-2021, 07:03 PM   #13
geezer#99
geezer#99's Avatar
Re: Saginaw setup
Afeered not!
Be nice to see the linkage on the side.
As best you can plus the shifter too.
Old 03-25-2021, 07:59 PM   #14
Overdriven
Re: Saginaw setup
Would you look at that. Shift rods...
Haha. Sorry, couldn’t resist
1967 C10 LWB 250 6cyl 3ott Panaramic cab “Layla”
1967 Camaro 327 ‘glide cruiser “Bailey”
Overdriven is offline   Reply With Quote
Old 03-25-2021, 08:31 PM   #15
geezer#99
geezer#99's Avatar
Re: Saginaw setup
Yupper!
But are they installed right!
A better pic will tell.
Old 03-25-2021, 09:31 PM   #16
Kcenderjim
Re: Saginaw setup
I will see if I can get something better. What part of the shifter do you need to see?
Old 03-25-2021, 09:50 PM   #17
geezer#99
geezer#99's Avatar
Re: Saginaw setup
pics from the side showing linkage and shifter.
