03-21-2019, 08:02 PM | #1 |
Parklight wire harness
I have a 72 Jimmy and the Parklight which is right below the double headlights in the front grill. I have not been able to find the harness that plugs into the light and the radiator support frame I have one but need two. 12 to 16 inches long, if I remember right it also is part of the turn signal.
03-21-2019, 10:47 PM | #2 |
Re: Parklight wire harness
Isn't the core support meeting place just a grommet and the harness is actually the whole front harness.
That runs from the cab to the battery... Try wiringhaness.com, then ebay once you have a part number. I actually have a complete new set of harnesses for a 72 Chevy that I paid a mint for. |
03-22-2019, 07:12 AM | #3 |
no the wire harness connects at the core support and to the parklight housing it is only about 12 to 16 inches long
03-22-2019, 07:52 AM | #4 |
Is it the same as the Chevy?
03-22-2019, 08:03 AM | #5 |
My 72 jimmy has the turnsignal and park lights are in the bumper, I should have two, since I changed my front end, if you need them let me know
03-22-2019, 01:53 PM | #6 |
[img]jpeg 050[/img]
This is what I am looking for |
03-22-2019, 03:20 PM | #7 |
The bulb socket is standard, but I can't see inside electrical side, probably two blades, but what configireation I don't know. One horizonal and one vertical.
Are you sure it's not a side marker light This is for a 67 turn signal [url=https://flic.kr/p/24EStSv]20190322_141112
05-05-2020, 08:15 AM | #8 | |
