Old 04-02-2020, 05:51 PM   #1
cochino12
It followed me home?
cochino12's Avatar
I've got a couple new dually projects
Picked up the white c30 early last month, before and after pictures. I've already got the interior finished up also.
The red truck I bought for work because of the dump bed. Not running currently but my mechanic should have it going for me hopefully soon. I think I'm going to lower it 3/4, should be a fun work truck.
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 04-02-2020, 05:55 PM   #2
cochino12
cochino12's Avatar
Re: I've got a couple new dually projects
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 04-02-2020, 06:12 PM   #3
SCOTI
SCOTI's Avatar
White CC cleaned up nice.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
Building a small, high rpm engine
with the perfect bore, stroke and rod ratio is very impressive...
like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar.
Cubic inches is like Indiana Jones with a cheap pistol....
Old 04-02-2020, 11:05 PM   #4
Loco83
Loco83's Avatar
Loco83 is offline   Reply With Quote
Old 04-03-2020, 07:49 AM   #5
focusedontheprize
focusedontheprize's Avatar
The white C30 looks great, who did you go with for the 22s?
focusedontheprize is offline   Reply With Quote
Old 04-03-2020, 12:54 PM   #6
cochino12
cochino12's Avatar
I tried ordering from a couple of companies in AZ but had a hard time getting pricing... I ended up ordering from wheelsamillion in FL. They were very easy to deal with and had them shipped in just a couple days.
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 04-05-2020, 09:29 AM   #7
Pontiac1976
Pontiac1976's Avatar
Vary Kool truck can't wait see it finnished
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 04-05-2020, 11:00 AM   #8
Nice trucks
1981 GMC High Sierra SWB Stepside
Board Vendors
It's scary when you start making the same noises as your coffee maker.
Old 04-05-2020, 01:00 PM   #9
SCOTI
SCOTI's Avatar
Are these milled/faced like the "companies in AZ"?
How much gap between the sidewall & outer fender lip?
Stock dually Dana 70 rear?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-05-2020, 08:14 PM   #10
cochino12
cochino12's Avatar
same as the other guys flat face outer wheel. Not much room between fender and tire, about 1/4". Stock dana 70 and no mods to the inner or outer fenders
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 05-23-2020, 05:27 PM   #11
cochino12
cochino12's Avatar
Dump bed truck is running, lowered 3/4. Id like to go a little lower but dont think I want to spend the $$ for spindles. Cleaned up the wheels today, next up straightening up the interior, getting all of the lights working, building a headache rack
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 05-23-2020, 06:08 PM   #12
Ziegelsteinfaust
I love your trucks.
The red flatbed needs 22's too.
Ziegelsteinfaust is offline   Reply With Quote
Old 05-23-2020, 06:31 PM   #13
lolife99
Old Guy
lolife99's Avatar
Really like the red single cab.
Keith
Convert to disc brakes.
WTB: Radio Delete Plates and clips.
lolife99 is online now   Reply With Quote
Old 05-24-2020, 07:14 AM   #14
Board Vendors
Old 05-24-2020, 04:12 PM   #15
farmall
Like the red one. Id go with a 6 or 8" wood headboard, loose the pipes and get some Timpte mud flaps. https://store.timpte.com/product?object=9794
1955 GMC 250 8 Flatbed
1971 C30 157" 350 4spd PS PB White With Blue Int 10' Flatbed
81 GMC K30 CnC 9' Flatbed 454 T400
71 LT1 Convertible, 72 Coupe
69 CJ5 V6, 75 CJ6 V8
67 M715, 72 M35A2 Bobbed, 95 XLC2
farmall is offline   Reply With Quote
Old 05-27-2020, 12:11 PM   #16
Pontiac1976
Really like the red 3/4ton very sharp.
Copyright ©2000 - 2020, vBulletin Solutions Inc.
