03-17-2012, 08:22 PM | #1 |
Starter Wiring Problem
I know on a point type ignition system the purple wire goes to the "S" terminal and the yellow wire goes to the "R" terminal and the battery cable goes to the big lug. My problem is my starter solenoid has no "R" terminal, therefore nowhere to put my yellow wire. It only has the big lug and the "S" terminal. It looks like nothing is broken and the solenoid was made that way. I guess I could get another solenoid but is there a quicker way to fix it?
I do not have a spare HEI sitting around anymore and I'd like to get this thing fired up. Anyone have any suggestions?
-Scott- |
03-18-2012, 09:34 AM | #2 | |
Java Mechanic
Re: Starter Wiring Problem
I got this from "e how":
Keith 11 Lincoln MKT -- Momma's wagon 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... |
03-18-2012, 10:07 AM | #3 |
Sounds like it would just be easier to get a new solenoid????
-Scott- |
03-18-2012, 01:18 PM | #4 |
Java Mechanic
It might be... or an HEI.
03-18-2012, 02:00 PM | #5 |
Definately going to an HEI in the near future. Just trying to get the truck running to see what condition the motor is in.
-Scott- |
03-18-2012, 02:53 PM | #6 | |
Msgt USAF Ret
You can run a Ford relay like this one below but it would be more permanent. The positive cable from the battery would split at the solenoid and continue on to the starter with the little jumper to activate the starter solenoid. The purple wire that goes to the starter solenoid is re-routed to the Ford solenoid so when the key is turned to start the relay closes and power goes through the large cable to the starter and the small wire also gets 12 volts to the coil + as shown. That wire will be hot anytime the key is on but no power will feed back to the solenoid so no diode is required.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
03-18-2012, 03:45 PM | #7 |
Thanks VetteVet. I like to run the Ford solenoid setup anyway (just cheap insurance for future starting problems).
I'm going to go ahead and use the advise on the hot wire to the + terminal on the coil and then unhook it after I get it started. So that wire is just to get it started and isn't needed for continuous running of the engine?
-Scott- |
03-19-2012, 09:26 PM | #8 |
Ok, got the truck running. Went ahead and changed the solenoid, wired it up, and she fired right up! Now the ignition switch either needs changed or the starter need shimmed because it hangs up and continues to spin with the motor. I think I will try the ignition switch first unless anyone has any more words of wisdom.
-Scott- |
05-19-2017, 10:45 PM | #9 |
Don't mean to chime in on this conversation, I have the same issue only running an HEI system. Some months ago I was having starter problems(solenoid), decided to go with the ford type solenoid setup posted on this website. Now I have no problems on startup other than the fact it continues to run for a few seconds after startup. What problems can come up if not fixed? In checking on shimming the starter I noticed the flywheel has a wobble , could this have been done buy this starter?
05-19-2017, 11:04 PM | #10 |
Various posters may want to learn a bit about electrical stuff and Ohm's law. Its not magic, and you should be able to think for yourselves a little...
One thing to think about is why not to use a ford solenoid, which adds another part to something people have trouble troubleshooting. Adding moving parts to a broken system is not making the problem easier to solve. Clue: The problem is usually resistive wiring. Last edited by franken; 05-19-2017 at 11:09 PM. |
05-23-2017, 05:07 PM | #11 |
Well that helps a lot Franken, Im assuming about 80% of the people that come on this forum are looking for a little assistance with a situation they have run into! Not all of us understand, and that is why we come here!
05-23-2017, 07:32 PM | #12 |
Msgt USAF Ret
Or maybe it's heat soak in the starter solenoid, which causes resistance, which the GM wiring cannot compensate for, which the Ford solenoid helps to deliver and overcome, giving the poor hobbiest a solution to a problem, that allows him/her to enjoy their vehicles without spending a ton of money.
I don't think Henry would take kindly to someone saying his solenoids were troublesome and not to use them. One thing I always think about when someone posts on the forum and asks for advice with a problem, is that maybe they are an IT specialist, or doctor or lawyer, or maybe they play a mean guitar, so I would never chastise them for not knowing Ohms law.
