01-31-2017, 06:49 AM | #1 |
Engine wont start when warm....
So, I have a 1971 307, 2 barrel, automatic, points distributor. When its cold it fires off great no choke needed, which makes me think the floats might be too low since i never need to choke it?
anyways, when its warmed up it cranks over fine so no heat shields needs for the starter or solenoid, but i have to hold the pedal to the floor and dump the carb to re-start. only visible issues Ive seen is the carb seeps at the throttle rod bushings. I have set the points/dwell, timing etc. flooding? timing? |
01-31-2017, 07:34 AM | #2 |
Re: Engine wont start when warm....
Does black smoke or any type of smoke appear once started? Sounds like carb needs adjusting.....
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
01-31-2017, 08:14 AM | #3 |
No smoke at all.
01-31-2017, 08:25 AM | #4 |
Have you manually looked when warm to see if indeed the choke is open.. and not flopping closed..
01-31-2017, 08:38 AM | #5 |
Back in the day I could never get more than 2 years out of a set of points. In our farm trucks we changed them every year. Just routine maintenance to keep them running good. Old points cause headaches. Sometimes those old coils fail when they get hot too.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
01-31-2017, 08:42 AM | #6 | |
Senior Car Nut
like b454rat says, I think it's time for a carb rebuild. if it was an edelbrock we"d all yell "heat soak" (percolation) I don't recall anybody having posted about that sort of problem with a 2 barrel but I guess it's possible. it this a recent problem? my guess, if it's the float it's either set too high (unlikely) or more likely fuel-logged (pin-hole in metal float or soaked plastic (?) float). could be trash in the needle/seat. easy enough rebuild, but kits are universal, lots of different gaskets for all the models. make sure you pay attention to whether or not the accelerator pump has a ball under it, some models do, some don't.
Larry Last edited by fleetsidelarry; 01-31-2017 at 08:50 AM. |
01-31-2017, 09:07 AM | #7 |
01-31-2017, 11:50 AM | #8 |
Post Whore
If you have to put the pedal to the floor it's because the carb is flooding out. By flooring it you are giving the engine a straight lean shot of air which finally vaporizes the fuel so the engine will start. Engines like rich starts...so stone cold it will be fine, but hot...it's flooded. Either the float is to high Or since you mentioned fuel seepage at the throttle shaft....it's time to check that carb out. Good excuse for a 4 barrel now.....People complain up the hill that Edelbrocks have problems....Holley's flood engines out just as bad if not worse under the same conditions.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
01-31-2017, 12:28 PM | #9 |
Sounds like the carb is super rich, float could be adjusted a little high or could have a little piece of grit in the needle and seat.
1973 Chevrolet C10 Stepside 454 |
01-31-2017, 02:28 PM | #10 |
i was thinking new points but they look good. could the condenser do that?
01-31-2017, 03:37 PM | #11 |
01-31-2017, 03:38 PM | #12 |
points are perfect and coil tests great
01-31-2017, 04:07 PM | #13 |
Post Whore
Did you check the coil's resistance?
01-31-2017, 04:11 PM | #14 |
01-31-2017, 04:14 PM | #15 |
Post Whore
Those are handy. lol We have one at the shop. If spark is good and you are sure the points are decent, I'd still be looking at fuel. Especially since you mentioned there is some seepage.
01-31-2017, 04:21 PM | #16 |
and if i hammer the throttle i get 1 solid pop out the carb.
01-31-2017, 04:22 PM | #17 |
Post Whore
Running lean because of a vacuum leak no doubt. Time to look through that carb.
02-01-2017, 12:58 AM | #18 | |
*** That's interesting ***
And... since nobody else asked, what is your initial timing set to? I like to make sure timing is straight before blaming the carb. Some of these symptoms could be compounded by retarded timing.
Tom Chevy by day... 1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E 2011 Chevy Caprice PPV 9C3 6.0L 1995 Chevy Caprice 9C1 1994 Chevy Caprice 9C1 #3 1995 Chevy Caprice Wagon #2 1995 Chevy Impala SS Mopar by night... 1969 Dodge Charger 1972 Chrysler Newport 2dr Hardtop (27K miles) Plus others... |
02-01-2017, 02:05 AM | #19 | |
as this is listed as a warm restart problem. It is easy to point finger at the carb.. and it maybe.. but... |
02-01-2017, 08:23 AM | #20 |
over flowing, the float was full.
02-01-2017, 08:56 AM | #21 | |
So remove the filter and see whats going on . Could be just a float needle and seat change is all thats needed . |
02-01-2017, 10:32 AM | #22 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Good point!...Your carb could probably use a rebuild. The fact that no choke is necessary during a cold start is evident of a rich situation. having to hold the pedal to the floor once warm is another as well as fuel leaking from the gasket that no doubt needs replaced. The 2G's are notoriously rich running carbs which is why (other than middle of the road sized primaries) they get worse mileage than the Quadrajets...Replace the questionable vacuum lines all the way down to the modulator and put a new 1/4" inch gasket under the carb after the rebuild and dont forget to protect the clean carb with a new inline filter. You need to learn how to adjust that choke because a properly adjusted carb will need some choke at start up...
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
02-01-2017, 10:42 AM | #23 |
Thank you all for the ideas, i needled through one by one, the float was half full and the valves look crappy. now im fighting with finding the right kit (which i can do on my own) but a float seems impossible since the tag is missing. its a 2G and parts people are ignorant now
02-01-2017, 11:06 AM | #24 | |
02-01-2017, 11:12 AM | #25 |
mine has NO stamps lol
