Old 04-08-2024, 04:09 PM   #1
Don D
GM Floor Shift Tilt Steering Column
GM floor shift tilt steering column for 67-72 Chevy truck. This column was a automatic column I converted into a floor shift column. It has been painted gloss black & the following parts are new. Turn signal switch & wiring harness with the correct curved wire connector, lower bearing, lower bearing retainer, turn signal lever, tilt lever, horn contact / cancel cam, upper & lower rubber seals, and hazard light knob. Ready to bolt in. $585.00 Plus Shipping / Shipping to the U.S. Only / Payment - Personal Check or Postal Money Order
$585.00
Don D is offline   Reply With Quote
Old 04-12-2024, 07:49 PM   #2
Don D
$585.00
ttt
Old 04-15-2024, 08:17 PM   #3
Don D
ttt
Sold locally.
Old 04-15-2024, 09:24 PM   #4
dec010974
dec010974's Avatar
Re: GM Floor Shift Tilt Steering Column
hello Don D. Do you have any more manual floor shifter steering columns, maybe a tilt version? Also I have a manual floor shifter column that I tried to rebuild. can you assist me with that? thanks in advance, clark.
dec010974 is offline   Reply With Quote
Old 04-16-2024, 11:07 AM   #5
Don D
I do not have any factory manual floor shift tilt columns. They are hard to find since there was not that many made. I do have another automatic tilt column I will be making into a manual floor shift column. It will look like a factory floor shift column when finished. Send me a PM about the column you have.
Old 04-17-2024, 08:59 PM   #6
dec010974
dec010974's Avatar
Message sent
