Old 08-12-2017, 01:27 AM   #1
hop sing
hop sing's Avatar
Cab mounting ?
well here's the deal got a 60 short bed t bar frame and got a 63 bbw cab I want to put on it wondering if anyone has done this before and what cab mounts need to be modified ? thx hop oh is 64-66 a different cab mount locations too ?
Save a tree support your local drag strip !!!
hop sing is offline   Reply With Quote
Old 08-12-2017, 11:31 PM   #2
Captainfab
60-66 Nut
Re: Cab mounting ?
The '63 cab mounts exactly the same as a '64-'66 cab. To mount your '63 cab onto a '60-'62 frame all you have to do is drill the front cab mount bolt holes farther out to match up with the mount bracket on the frame. If you still have a '60-'62 cab, you can use that as a reference. Then use the '60-'62 cab mount rubber cushions.
Old 08-13-2017, 12:19 AM   #3
hop sing
hop sing's Avatar
Re: Cab mounting ?
Mahalo Captn !! Hop Sing
