Old 01-03-2018, 12:19 AM   #26
Robznob11
Robznob11's Avatar
Re: Best Under Bed Fuel Tank Conversion.
Well you should not have to blend bedliner if you get a fuel door. Here is a pic of how the 2002 camaro tank sits in mine.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 01-04-2018, 03:53 PM   #27
Justin Jones
Rob I just wanted to say your truck looks awesome. Thanks for posting pics.
Justin Jones is offline   Reply With Quote
Old 01-04-2018, 04:09 PM   #28
Project1970
14.1 @ 96MPH
Project1970's Avatar
Yeah, the license plate door seems to be the only option that requires no modification to either the bedlined or exterior painted surfaces of the bed.
I've also got rear leaf springs to contend with, too.
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 01-04-2018, 08:48 PM   #29
Robznob11
Robznob11's Avatar
Thanks sir!
LED TAILS
Old 01-12-2018, 11:52 PM   #30
SabbathFanatic
SabbathFanatic's Avatar
Originally Posted by mi396ss View Post
Thanks, that’s good to know. Although I’ll still probably go with this one since it’s bigger and cheaper.
https://www.amazon.com/Spectra-Premi...=spectra+GM15C
Hey 396, I'm getting some more parts together for my build. Just so you know, that tank is only $80 on rockauto
1971 C10 - LQ4/4L80E swap in progress
1988 K3500 - 8.1 swap planned
SabbathFanatic is offline   Reply With Quote
Old 01-13-2018, 09:48 AM   #31
mi396ss
I didn’t know what the shipping would be so I ordered everything from amazon. Tank, sending unit and straps. I cut out the rear cross member and spare tire bracket and the tank fits perfect between frame rails. I haven’t gotten any further with it like seeing how the behind the plate filler will work. I have a little different situation since I have a body lift and custom rear bumper.
mi396ss is offline   Reply With Quote
Old 01-15-2018, 02:13 PM   #32
SabbathFanatic
Sounds good. I'd love to see some pictures once you're done.
Old 01-15-2018, 11:27 PM   #33
Justin Jones
I would too you guys. I ordered the '72 Blazer tank that's made by Tri-plus I think. Seems to be made fairly well. It's a 21 gal and has the filler neck on the side. That makes it a little easier to work with a step side bed, maybe. We are going to do the fill neck behind the running light socket deal.
The downside is that it doesn't have a big enough hole in it for a fuel injection pump assembly, nor a baffle. We bought the Holley retro fit pump assembly to work with our system. Hopefully it works out.
Old 03-28-2021, 09:17 PM   #34
mikeyptv
Junior Member
Do you have a photo to share of how long that Caprice tank hangs?
Originally Posted by OBS454 View Post
I installed a poly tank from a 9C1 Caprice. I use a small external electric pump but the factory setup was for the SPFI LT1 and I think delivered 50+ PSI Used the Caprice mounting straps and fabbed front anchor mounts. Had to remove spared tire cross piece. It is visible from the side(s) and rear but not much.
mikeyptv is offline   Reply With Quote
