Old 07-02-2006, 09:25 AM   #1
Dual exhaust routing @ crossmember
How are you guys routing your pipes at the trailing arm crossmember w/o going through it(custom)?Big blocks had duals,what did the factory do?It`s been so long since I`ve had a coil spring truck,I can`t remember.
Old 07-02-2006, 10:48 AM   #2
ChevyDude
Re: Dual exhaust routing @ crossmember
I believe the exhaust hung just below the crossmember.
ChevyDude is offline   Reply With Quote
Old 07-02-2006, 11:27 AM   #3
Then,up to the inside of the t-arms,I guess?Thanks,BTW.
