Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 01-08-2020, 05:19 PM   #51
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Re: Creamsicle: My 70 K10 SWB is about to get sweeter
Since I was moving the fuel tank to the rear of the truck, I kicked around what type of fuel fill I wanted. I looked at everything from bed fill, to side fill, license plate, side marker, tail light, and on and on. I didn't want to make this too complicated so I opted for the bed fill. I didn't want to have to do a bunch of body work and repaint the bed, since my bed floor isn't the greatest to start with. So I decided to install a bed kit in order to mount the Boyds 2" fuel fill connection. Since I'm calling this my Creamsicle build, I wanted to add a special touch to the bed floor.
Installing the aluminum bed rails onto bed floor.
Laying down the bed floor.
Ready to install the stainless bed strips.
Just need to cut in and install fuel fill, then bolt everything down.
~ Dan
My Chevy Pics:https://app.sugarsync.com/iris/wf/D7...115878_6210284
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 4 spd, PS, PB, AC, AM/FM
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 01-08-2020, 05:35 PM   #52
derotoreut
derotoreut's Avatar
Worked on installing the Boyd's 2" bed floor fill kit https://fueltankparts.com/products/b...60b74118&_ss=r
First I drilled the hole in the bed directly above the Rick's tank filler connection (touched up around the hole where I drilled later).
Laid out the hole for the fill kit.
Used my hole saw to cut out the large hole, then drilled all mounting bolt holes.
Moved into position and attached connection line.
Finished product!
~ Dan
Old 01-09-2020, 11:33 AM   #53
First c10
First c10's Avatar
Hey Dan that bed set up is pretty nice looking.... where did you get it?
I like the decal!!!!
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/4.8L-ly4/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 01-09-2020, 02:27 PM   #54
derotoreut
derotoreut's Avatar
I got the bed kit through Smokey Road Rod Shop. Frank and Rhonda are great people to work with. Check them out.
https://www.smokeyroadrodshop.com/
~ Dan
Old 01-10-2020, 09:17 AM   #55
derotoreut
derotoreut's Avatar
I'm going to try to route my AC and heater hose lines through the passenger side fresh air vent. In order to make the routing easier, I cut away some of the edge on the vent opening. This will give more room for the hoses. This vent will be closed off anyway due to the Vintage Air installation.
~ Dan
Old 01-10-2020, 10:52 AM   #56
C.I.Blazer
Junior Member
Great project. I may have missed it, but what headers did you end up using to replace the Doug Thorley's?
C.I.Blazer is offline   Reply With Quote
Old 01-10-2020, 02:06 PM   #57
derotoreut
derotoreut's Avatar
The headers I'm using are Speed Engineering model 25-1021. They are kind of a short-to-mid length header. I was considering their long tube headers, but their website specifically states they do not fit 4WD. I didn't want to chance it.
I fit up the headers and so far they look good. I'm happy with the choice because I'll have to custom fit the exhaust around the transfer case cross member anyway. If I went with long tubes, I believe they would have come down lower and pointed directly at the cross member and it may have been more difficult to pipe around.
https://www.speed-engineering.com/fe...c10-truck.html
~ Dan
Old 01-13-2020, 08:54 AM   #58
C.I.Blazer
Junior Member
Looks like a lot of people have had luck with these on their 4WD swaps. I am going to order a set and give them a try. Thanks for the help! Keep up the great work.
Old 01-15-2020, 12:00 AM   #59
derotoreut
derotoreut's Avatar
Since I'm going with a 4L60E transmission and column shift, I had to modify a high hump for my transfer case shifter only. Found a good high hump and cleaned it up and painted it. Then marked out for my transfer case shifter arm and made the cut.
~ Dan
Old 01-15-2020, 12:07 AM   #60
derotoreut
derotoreut's Avatar
I am planning to mount my PCM under the passenger seat. The seat will be used with a set of Blazer seat tilt brackets. I drilled a hole and put a grommet in the area where the center console hump meets the floor pan. You can see I'm using rivet nuts to mount my console. I used them for my bucket seat mounts too, in the areas where I didn't have the stock mounting nuts.
~ Dan
Copyright ©2000 - 2020, vBulletin Solutions Inc.
