04-01-2015, 07:51 PM | #1 |
Lower hinge pilar pocket install
Does anyone have pictures of this in progress? I have read a ton of build threads and searched also. Thanks for all the help so far. Been picking away at and making progress on the cab.
Mike |
04-01-2015, 08:46 PM | #2 |
Re: Lower hinge pilar pocket install
Here is mine starts around post 54. Driver side did most of it, passenger, just the lower part. The cab side was not too bad, just made some patch panels and welded them in.
http://67-72chevytrucks.com/vboard/s...233305&page=24
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
04-02-2015, 01:33 PM | #3 |
no pics, only recommendations
just because the patch plate is a foot long and full width of the door jam doesn't mean you need to use the whole patch cut out the rusted area and cut the patch to match, i used 10% of the patch panel that imo, was easier than doing the whole patch and cutting all the spot welds out
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
04-03-2015, 01:28 AM | #4 |
I'm doing a 1959 Viking (2Ton)
Please excuse the mess . before . . . . . I'm also doing floor there are 4 pieces Lower door plate hinge (rear of pocket) opposite plate One hole for back side of hinge(outer front pocket) lower plate holds fender on outer brace . here are pictures from a good cab ( Pass side) . . . . parts removed . . . . . picture of inside looking out lower hinge pocket . . . . . . . . . . . . . .
My Spelling is Not Incorrect...It's 'Creative' . . 1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E http://67-72chevytrucks.com/vboard/s...d.php?t=789617 59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341 |
04-03-2015, 11:15 AM | #5 |
Here's some pics that might help: There used to be videos with these but it looks like the videos are no longer there.
http://www.hotrod.com/how-to/engine/...modifications/ http://webrodder.com/article/cab-cor...-trucks-part-a |
04-03-2015, 06:59 PM | #6 |
I'm doing the work on another forum with pics. Hotrodders web site go the the lounge and then projects/builds Titled my new 59 truck project.
04-03-2015, 09:46 PM | #7 | |
. Quote:
04-03-2015, 10:34 PM | #8 |
04-03-2015, 11:31 PM | #9 | |
.great thread OrrieG 7 years and 47 pages that's going to take me a while to get through I did like the use of the astro parts for the steering column shaft and eldo tilt wheel . .
04-06-2015, 10:56 PM | #10 |
I wanted to add this
Is athread with more info and pictures of hinge pockets rebuild...Sp . . http://67-72chevytrucks.com/vboard/s...d.php?t=443569 . . . . . . . . . . . . . .
