Old 01-07-2020, 11:07 PM   #1
KevinK7
KevinK7's Avatar
67-72 Frame ID? ( 1/2 ton, 2WD)
I've done a number of searches and summarized what I found. I am by no means the expert here, just trying to put a list together. If anyone has anything they can add, Confirm, or more importantly, correct, please let me know and I'll update.
Thanks for the replies thus far
I plan to go look at a couple SWB frames and wanted to have an idea up front what to look for in an attempt to ID the frames as to what years they are. Needless to say the first thing I'll look for is the partial VIN stamp, but other than that, WHAT ELSE is there to look for?
My plan" I currently have a '68 LongBed C10 that I plan to convert to SWB. I will be installing drop, disk spindles, lowering springs and converting to 5lug axles (4.75 pattern).
Questions:
1.) With the radiator support mounts, what specifically is different from 67 and 68, ..and 69-72?
2.) For a '68 C10, converting from LWB to SWB (noting I will be swapping out spindles) will all year frames (67-72) be equally compatible?
3.) I know the SWB wheelbase measurement is 115" (LWB is 127") but on a bare frame, where specifically would this be measured?
3.) Realizing limited pics, but based on the photos below, (I don't know the VIN# stamps yet), what year frames do you see? (Assuming both 6 lug)
Frame#1:
Frame#2:
'68 C20 Utility 396 4sp (BuildThread: http://67-72chevytrucks.com/vboard/s...d.php?t=806904 )
'68 C10 50th
KevinK7 is offline   Reply With Quote
Old 01-08-2020, 05:25 AM   #2
my kids toy
Re: 67-72 Frame ID? ( 1/2 ton, 2WD)
Questions:
I am interested to know this as well because I have a 72 frame and I am putting a 67 front clip on it
my kids toy is offline   Reply With Quote
Old 01-08-2020, 05:57 AM   #3
OL SKOOL
OL SKOOL's Avatar
I went the opposite 70 truck put a 68 frame under it. The only difference I found was the radiator support brackets are flush with the top of the frame on your 72. The 67 will be lower then the top of the frame. I had to make sure there was a dimple in the frame for the steering box . You won't have to worry about that using the newer frame. That is all I found cab mounts might be different on a 10 and 20 frame. Mine were both 1/2 ton and were the same. I looked I don't have a pic available of the front of the frame figures. Hope that helps.
OL SKOOL is offline   Reply With Quote
Old 01-08-2020, 10:48 PM   #4
weim55
If it matters my Fremont California built 67 short fleet has The VIN stamped in two places on the frame: next to the steering box and below the Rocker panel on the driver side. The frame is not dimpled for the Power steering box.
Steve weim55 Colorado
weim55 is offline   Reply With Quote
Old 01-08-2020, 11:17 PM   #5
KevinK7
KevinK7's Avatar
Thanks for the info, I updated the table to reflect.
...still wondering what's different about radiator support brackets on a '68 frame.
'68 C10 50th
Old 01-08-2020, 11:29 PM   #6
Jason Banks
Jason Banks's Avatar
Pretty sure you will find the 67 and 68 core support brackets on the frame are the same. They use the same mounts and core supports.
Aparently there are plenty of early 68 frames that are not dimpled for power steering.
Another difference you will find is the width of the top of the frame on the passenger side in 67 was wider because big block was not available. Discussed Here - http://67-72chevytrucks.com/vboard/s...=784551&page=2
I'm pretty sure most of them have the last part of the VIN in 2 places on the top of the drivers side frame rail. By the steering gear and under the cab.
Jason Banks is offline   Reply With Quote
Old 01-09-2020, 05:43 AM   #7
OL SKOOL
OL SKOOL's Avatar
Here is a pic of a 68 frame mount holes are smaller.
Old 01-09-2020, 10:36 AM   #8
KevinK7
KevinK7's Avatar
I will update the following:
- 67/68 Core support brackets (could be) the same, smaller holes than 69-72.
- Early 68 frames may have no PS dimple.
- VIN# stamp in two places, near PS pump and on DR frame side under cab
- 67 frame wider PASS side top (Big Block not yet available)
'68 C10 50th
Old 02-03-2023, 12:44 PM   #9
MikeandCheryl
Were you able to complete this chart? I'm looking for the differences between a K10 frame and a C10 frame. In the 'yellow' box in the original post, you mention the differences between the two. Perhaps this post has gone quiet, but perhaps you have more information.
MikeandCheryl is offline   Reply With Quote
Old 02-03-2023, 01:09 PM   #10
Getter-Done
Getter-Done's Avatar
This is an interesting chart
I am subbed for more info
KevinK7 last post and visit was 09-12-2022.
Maybe try sending him a PM because some members aren't
getting e-mails about subscribed post.
84 Chevy K-20
Old 02-03-2023, 01:58 PM   #11
Grumpy old man
Grumpy old man's Avatar
This thread should help answer your question .
http://67-72chevytrucks.com/vboard/s...d.php?t=224618
Old 02-04-2023, 10:50 AM   #12
MikeandCheryl
This was a very good link, Mr. Tennessee. Thanks. I've got my frame down to nothing and sitting on sawhorses - i'll figure out a photo to add to this, and the other post. It's definitely interesting to see the curves in the frame where the coils would sit - mine is a K10 so the frame is straight there. Good post.
Old 02-05-2023, 07:31 AM   #13
67 cst swb
67 cst swb's Avatar
This is a work in progress. I love it !!!
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
2002 Chevrolet 1500HD 4x4 Crew Cab 6.0L 4L80E Red
67 cst swb is offline   Reply With Quote
Old 02-06-2023, 03:12 PM   #14
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
C10 2WD came standard with rear coil springs, however leaf springs were an option.
The partial VIN is in two places, as:
The LH frame rail’s top is stamped in two places with the year (1), factory location (Z) and the VIN’s serial number. One is between the carrier bearing cross member and front exhaust hanger. The other is in front of the motor mount platform. .
Also, FYI
The RH frame rail ‘s exterior wall is stamped 3987552 – 572 and 4-23-26, located behind the front cab mount, on my 71 SWB 2WD
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
