10-26-2017, 09:24 PM | #1 |
What year truck do I buy brakes for?
I have a 1961 K20 but it has what I believe are GM 10 bolt rear axles on it. It is a 6 lug truck, and the rear axle says GM28 on it. I just don't know what year the axle came out of which makes it difficult to buy the right parts, so I was hoping you guys would know
Thanks! |
10-27-2017, 07:40 AM | #2 |
Re: What year truck do I buy brakes for?
Pull the cover and look for dates. There might be codes on the axle housing too, but only ever did that once. NYS likes to rust everything out so can’t be read.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
10-27-2017, 07:50 AM | #3 |
Can you post a pic? Is it a leaf spring or coil spring axle?
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
10-27-2017, 01:47 PM | #4 |
if it already has parts on it take them off and bring them to the autoparts store and see if they can id them. i always thought pretty much all the 6 lug gm 10bolt stuff was the same. just go in there and see you need calipers, pads or whatever you need for a 1985 chevy k5 blazer. good as a chance as any
