Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 11-07-2018, 03:31 PM   #2976
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
OK EPIC fail, plan B
went down to wires before it would pass thru grommet
[url=https://flic.kr/p/2bkwHdP]20181107_102902
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
Jim
jaros44sr is offline   Reply With Quote
Old 11-09-2018, 12:09 AM   #2977
AJs72K5
AJs72K5's Avatar
Re: PO has me PO'd
That rubber inside the grommet will stretch. It's a bear, but it will. I have two of those on the truck, one for the FAST wiring and another for misc stuff. The second one has over an inch of wiring thru it, wrapped in braided sleeve. Getting the 4L80 harness and plug thru it was a nightmare...until I got creative.
Here's what I did.... I took a transmission funnel (lubed with lithium grease) and gradually ran it thru the grommet to open it up. Think speculum. Then cut the end of the funnel off and passed everything thru. Pulled the funnel back out and cut it off the harness.
- AJ
Cruiser Crawler Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 11-09-2018, 05:50 AM   #2978
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Thanks for the tip!!! Bear, is a understatement, there were times, it woundn't budge. I was thinking lube, but wasn't sure.
Waiting for my 1 1/2" sheathing to come in from( F-6) Wire Care, then I can put it all back together, and start to make my connections
Thanks for the help
SAFETY FIRST
Jim
Old 11-15-2018, 06:51 PM   #2979
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
[url=https://flic.kr/p/2bwTmvD]20181115_120946
With my skills of rod tying and fly tying, I may have found a way to keep the skrunky sound out my shielding, wraping thread around it seems to keep it aligned, we'll see as I keep working on it
[url=https://flic.kr/p/2cVQW1R]20181115_163755
It seems that If you twist the shielding, it will allow it to lay better...follow the white tracer
SAFETY FIRST
Jim
Old 11-16-2018, 12:20 AM   #2980
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
[url=https://flic.kr/p/2bQddxd]20181115_231054
JMHO< but seems the rubber strecky tape wins out over the pure vynil
SAFETY FIRST
Jim
Old 11-25-2018, 06:00 PM   #2981
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Epic fail, part #2, 1A
still scrunky, used 3/4" wire care and it slips under corrugated , with bushing taped in. Marked with paint stick to keep it aligned. Now has support
SAFETY FIRST
Jim
Old 11-25-2018, 08:25 PM   #2982
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
[url=https://flic.kr/p/2c2kccs]20181124_093134
[url=https://flic.kr/p/2aodgBu]20181125_094253
[url=https://flic.kr/p/R21cYE]20181125_101749
SAFETY FIRST
Jim
Old 11-27-2018, 01:00 PM   #2983
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Repin coil connecters install connecters
[url=https://flic.kr/p/2dcvTEa]20181127_104252
SAFETY FIRST
Jim
Old 11-30-2018, 11:03 PM   #2984
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
This is the saw that I will be using to cut the hole in the firewall. I've turned the RPM down as low as I can get it. I like the grit better, as it doesn't seem to bite in as muchas a saw blade
[url=https://flic.kr/p/2bSQHgx]20181130_125421
SAFETY FIRST
Jim
Old 12-04-2018, 08:25 PM   #2985
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Large hole in firewall, cutting tool turned up a larger than expected burrr. Thought I was using a flow drill, 1/2 hour with a large file cleaned it up. now on to the wire harness
[url=https://flic.kr/p/2dmZGJT]
Afternoon spent in the Camaro, brunch with wifey and toy shop for Grand children
SAFETY FIRST
Jim
Old 12-06-2018, 09:43 PM   #2986
lks dcvn
lks dcvn's Avatar
Re: PO has me PO'd
You have way more patience that I do Jim! Looking good.
lks dcvn is offline   Reply With Quote
Old 12-07-2018, 09:18 AM   #2987
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Thanks Bud, but what else would I do with my retirement. I bought all my tools to do this, over the last 40 years.
I just wish I knew what I was doing, so I could explain it to the forum.
Harness is now thru the firewall, just have to shorten wires to make it fit
[url=https://flic.kr/p/PDSkHr]20181207_081647
SAFETY FIRST
Jim
Old 12-08-2018, 09:38 AM   #2988
zicc1835
zicc1835's Avatar
Re: PO has me PO'd
that cleaned up real nice Jim whats it lok like on the engine side ?
zicc1835 is offline   Reply With Quote
Old 12-08-2018, 12:12 PM   #2989
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Shorten wire, reattach connecters, repin wires, seals, study schmatic
I guess you could say that was a test fit....
probably pull runner, to gain access
My head hurts just thinking about it.
[url=https://flic.kr/p/PF9V1a]20181208_102117
SAFETY FIRST
Jim
Old 12-08-2018, 07:23 PM   #2990
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Zicc, thanks for the interest, but I may get my oil pan back up first, since the oil has drained out of the engine, I want to prime it back up thru the new oil filter and lines I installed, see what the gauge reads, and then rotate crank shaft, it seems a bit solid. Maybe put something down the bores
any work on your project or are you still traveling alot?
SAFETY FIRST
Jim
Old 12-08-2018, 07:59 PM   #2991
zicc1835
zicc1835's Avatar
Re: PO has me PO'd
Been travling alot Jim, with the fires in NorCal and acquisitions across the US the company is doing, been a busy year and will continue at least thru Q-1. only getting some of the plumbing, brakelines almost complete, exhaust next cab on for fitment hope i can do all that this winter....i been following your progress
thanks Merry Christmas
Jess
Old 12-08-2018, 09:35 PM   #2992
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
I gotta say I miss the fires I used to put out for the companies I worked for over the years(sometimes) then I work on my truck and forget it. But, I do miss the money
Maybe we can get together over the holidays, bring wifey
want to buy a bore scope, see what's going on in the chambers
SAFETY FIRST
Jim
Old 12-09-2018, 11:26 AM   #2993
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Alittle over-exhubriant....
wires are to long, should breake out closer to fuel regulator
[url=https://flic.kr/p/2dstwQ8]20181209_094631
SAFETY FIRST
Jim
Old 12-12-2018, 09:53 AM   #2994
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Needed more room to work, had to pry up( about 1/4" ) fuel rails, left bolts attached, to get runners off, also v/c's
[url=https://flic.kr/p/2c6hswi]20181210_112352
Now to bring wires out at coil connectors
SAFETY FIRST
Jim
Old 12-12-2018, 09:56 AM   #2995
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
This bolt has to come out to raise, do not pry on fuel rail cross tubes
[url=https://flic.kr/p/2c6hv28]20181210_112424
SAFETY FIRST
Jim
Old 12-12-2018, 10:16 AM   #2996
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Also, trying to reconfigure shifter boot, from square body turned upside down. Will have to section the aluminum ring
[url=https://flic.kr/p/PJYTpR]20181211_093234
SAFETY FIRST
Jim
Old 12-19-2018, 06:35 AM   #2997
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Note to self,DON'T use duct tape in harness...gluey mess... goo be gone
[url=https://flic.kr/p/PUe9rn]20181219_051346
SAFETY FIRST
Jim
Old 12-19-2018, 08:08 AM   #2998
litebulblsc
litebulblsc's Avatar
Re: PO has me PO'd
I use painters tape to hold the wires together while making the harness. It is easy and clean to get off. Then once it is all good, go back with the electrical tape.
litebulblsc is offline   Reply With Quote
Old 12-20-2018, 08:47 PM   #2999
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Thanks for the tip, I'll keep in mind as I go further into the harness
SAFETY FIRST
Jim
Old 01-05-2019, 08:11 PM   #3000
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Since I relocated my trans shifter to a trans mount I opened up a hole for the twin e-brakes, single rear wheel each. Stock console should go back to the oem location
[url=https://flic.kr/p/23pNWhk]20190105_105331
secret santa gave me a trans temp unit, waiting on mount bowl from auto meter
SAFETY FIRST
Jim
Copyright ©2000 - 2019, vBulletin Solutions Inc.
