Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 07-14-2017, 04:23 PM   #1
Jermsjunk
New guy here with 1970 C50 grain truck vibration question
Hey all! I'm hoping to get some help on my grain/dump truck. In 4th gear around 45 mph I get a loud metallic vibration seeming to be coming from the carrier bearing/center support bearing. Going under the truck I get a lot of driveshaft movement suggesting the same. Can someone point me to a supplier or other common problem with this truck. I really don't know anything about it so any help is appreciated.
Jermsjunk is offline   Reply With Quote
Old 07-14-2017, 07:50 PM   #2
C10 - C90 Bill
C10 - C90 Bill's Avatar
Re: New guy here with 1970 C50 grain truck vibration question
You should be able to get the Center Supports at your local parts dealer. Try to get good quality ones. Maybe someone on here can recommend a good brand. Check the Center Bearings when you have it apart. Most of the time it is just the Supports that are the problem.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
C10 - C90 Bill is offline   Reply With Quote
Old 07-14-2017, 09:49 PM   #3
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
U joints can make a metallic noise as well when very worn. Here's a Timken catalog, they show several applications for driveshaft supports on page 14 and 15 for older medium duty trucks, you'll have to measure the bearing to get the right size.
http://www.timkenbearings.com/en-in/...Guide-2010.pdf
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 307/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 fire truck 478M V6/5 spd 1200 gallon pumper
Robert1970C20rstbukt is offline   Reply With Quote
Old 07-17-2017, 01:57 PM   #4
Jermsjunk
Thanks for the responses All.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
