Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 04-13-2017, 10:58 AM   #1
1966burb
1966burb's Avatar
Need special bolt for jump seat for 66 burb
I know this is a long shot, but throwing it out. I need one special bolt for the pivot or hinge point on my passenger folding jump seat on my 66 burb. The part that is special is the shoulder under the head of the bolt. I have searched shouldered bolts and have found nothing close. I may have just make a sleeve that slides on the bolt but OD dimension is odd so it will need to be turned down on a lathe. Hoping someone has a rusted out or broken frame in their special junk that has the bolt I need.
1966burb is offline   Reply With Quote
Old 04-13-2017, 03:08 PM   #2
Southcity
Southcity's Avatar
Re: Need special bolt for jump seat for 66 burb
Curious to know if the bolt in your pic is stripped and unusable? if not and it's just a bit rusty it would be easy to restore it to like new condition. Or is it that you only have one and need more than that?
66 GMC Suburban Custom
Southcity is offline   Reply With Quote
Old 04-13-2017, 08:52 PM   #3
1966burb
1966burb's Avatar
This is the good one. Other one is broken. J
Old 04-13-2017, 09:11 PM   #4
Southcity
Southcity's Avatar
Thought that might be the case, good photos and drawing btw. Agreed that to match exactly would mean either someones rare spare parts bin or salvage yard. The alternative would be to find something that looks the part and functions as the stock piece with little to no modifications. I'm sure others will chime in too, here is a link to PIC which has both stock sized and custom made precision shoulder screws:
http://www.pic-design.com/precision-...er-screws.html
Old 07-12-2017, 09:29 AM   #5
1966burb
1966burb's Avatar
Still looking for one bolt. I may just have to find something close and have it machined to match.
Old 07-12-2017, 01:55 PM   #6
pimpston65
globetrotter65
pimpston65's Avatar
i know of a spot where such a bolt is to be had!!! is it the bolt that attaches to the front two curved legs for the jump seat? if so i can hit this place up this week end...
pimpston65 is offline   Reply With Quote
Old 07-13-2017, 12:06 AM   #7
Captainfab
60-66 Nut
I would just get a couple 5/16" x 1/2" button or pan head bolts, have a couple sleeves machined to ~.314" ID x .440 OD and .125 long and slide the over the bolts. That is not ideal but should last for quite a while.
Old 07-13-2017, 01:11 AM   #8
1966burb
1966burb's Avatar
Yes, thanks, I have already got the bolts and was headed that direction with making some sleeves. j
Old 07-14-2017, 09:48 AM   #9
1966burb
1966burb's Avatar
Here are some pics of the bolts in seats.
Old 07-14-2017, 10:29 AM   #10
pimpston65
globetrotter65
pimpston65's Avatar
these are the seats from the bone yard i hit
Old 07-17-2017, 09:28 AM   #11
1966burb
1966burb's Avatar
One bolt looks correct for sure. You would want to soak those with PB Blaster or sometime to keep from breaking them off during removal. J
Old 07-17-2017, 03:10 PM   #12
pimpston65
globetrotter65
pimpston65's Avatar
i got a bag oh tricks for bone pickin, i even take a propane torch. if you want it you gotta tell me cuz its an hr away a i go as needed.
Old 07-17-2017, 11:30 PM   #13
1966burb
1966burb's Avatar
One bolt is holding me up. I could really use one. Don't make a special trip. I have a regular bolt holding it in place for now. J
Old 09-01-2017, 11:00 AM   #14
wahl4m
i use a self locking nut on the inside of the seat frame ! that way the bolt i wont be tightened up too far- & it lets the pivot point swivel & somebody getting in the back -wont scrape there leg or body on the nut edges ??
wahl4m is offline   Reply With Quote
Old 09-19-2017, 10:56 PM   #15
1966burb
1966burb's Avatar
Machined a sleeve to fit on a bolt and got the seat bolted back in. Would still like to find an original bolt. Jim
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
