Old 03-08-2020, 08:04 PM   #1
Backpayne
Truck goes in reverse, barely moves in drive
I'm sure this th400 is toast, but wanted to ask first. As stated in the title, my c10 moves in reverse just fine, but if I shift to any forward gear I can rev the engine but it will just crawl forward. Is this a sign that the bands/clutches are toast?
This is a th400 I tried to rebuild for fun. I have a spare in good condition so I'll just swap them.
Backpayne is offline   Reply With Quote
Old 03-10-2020, 11:52 AM   #2
68 P.O.S.
Re: Truck goes in reverse, barely moves in drive
Check your fluid level. If your trans is low on fluid it will do this as well.
What kit did you use to rebuild it?
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 03-13-2020, 11:45 AM   #3
vince1
Here's a schematic.
http://www.tcsproducts.com/media/1/T..._Nov2012_1.pdf
Many years ago the TH400 in my 77 Jeep Wagoneer failed. It was because of a worn reverse band. Is the other band for forward gears?
vince1 is offline   Reply With Quote
Old 03-13-2020, 02:54 PM   #4
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
If your looking to get rid of the bad 400 for cheap I'd be interested...
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 03-16-2020, 11:52 PM   #5
Backpayne
Fluid level was good. I have removed the transmission and will be replacing it with the known working transmission.
It's a BOP th400, and shipping wouldn't be worth the effort.
