11-19-2018, 03:20 PM | #1 |
C50 Cab Differences
Was wondering if anyone could tell me the differences on a cab from a C50 to a C10? From a quick glance it looks like the only thing that is really different is the front fenders/clip. Doors look the same to me. Hood is interchange-able? Thanks in advance.
1971 Chevrolet K10 - SWB, 5.3LS, 4L60e 1970 Chevrolet K5 Blazer - Project 1969 Chevrolet C10 - SWB, 350 Holley Sniper, 700r4 1969 GMC Suburban - 5.3 LS, 4L60e |
11-19-2018, 03:40 PM | #2 |
Re: C50 Cab Differences
Cab mounts and trans jump is all I believe.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
11-20-2018, 12:36 AM | #3 |
60-66 Nut
There is no trans 'hump' as it is just flat across. Then there is an extra brace across the lower part of the firewall on the engine side, plus I believe the '60-'66 medium duty cabs all have the '60-'62 front cab mounting location. Other than that, the cabs are basically the same.
11-20-2018, 04:00 PM | #4 |
Anyone ever put a C50 cab on a C10? I'd be interested to see how much work it would be
11-20-2018, 08:08 PM | #5 |
Check The Champ, Demonstrator
Where the lower inner fender bracket is longer but is a bolt on item.
The additional brace as mentioned above. 100+ spotwelds to drill out. Hole beside the seat drivers side for the vent for the power brake booster. Look for a bolt in front transmission tunnel . You can cut out one from a light duty cab and bolt it in. Additional firewall hole on earlier for hydraulic clutch.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
11-21-2018, 09:45 AM | #6 |
This is also used on a 10 series with power brakes.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
