Old 04-01-2015, 10:38 PM   #1
ssuesens
ssuesens's Avatar
Won't start - obvious things to check?
Phone just rang. Son is stranded 3 blocks from the house - his 71 C10 died at a stop light. I just towed him home and will go look at it tomorrow morning.
Here is what I know. The motor has always been VERY dependable - it is his daily driver. Last Sunday we replaced soft fuel line for a hard fuel line from fuel pump to fuel filter before carb It has been working fine until tonight. Tonight we checked fuel filter and it had gas in it. Checked carb and it had plenty of fuel as well. Cranking sounded normal - just didn't start.
I know from experience it is usually the last thing you messed with but it appears it is getting plenty of fuel.
So I ask the better mechanics than me on this board (almost all of you) what you would look at first.
Additional info:
350 AT
HEI Dist (Petronics flamethrower)
Holley 4 barrel
"Life is too short to use cheap zip ties"
64 C10 SWB
71 C10 LWB
72 C10 LWB
ssuesens is offline   Reply With Quote
Old 04-02-2015, 01:37 PM   #2
cooperhw
cooperhw's Avatar
Re: Won't start - obvious things to check?
I don't know about the flamethrower in particular, but HEI failure is usually what happens all of a sudden like that. In a stock HEI unit there is a small black horseshoe shaped unit that takes 2 1/4 bolts to hold it in. There is also wires that plug into it. Every time I have had to work on a "suddenly died" situation that an HEI is in it's always this. Pull a plug wire (hold it near an exhaust bolt) and turn over and you probably don't have any fire or spark.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 04-04-2015, 01:00 PM   #3
Raider Rudy
Raider Rudy's Avatar
He is talking about the distributor mobule and it is highly possible that it has malfunctioned.
1969 Chevy Long Fleet Custom C/10 (2nd owner)
1971 Chevy Short Fleet Custom C/10 (2nd owner)
2001 Chevy Silverado Ext Cab
Raider Rudy is offline   Reply With Quote
