03-15-2016, 01:03 AM | #1 |
Re: rear hitch spare tire holder
too bad you chopped up the hardware. some of it is unique and typically not available through vendors or Ace hardware stores.
03-15-2016, 11:03 PM | #2 | |
Custom fuel tank and class V hitch going around it is far better use of space than for a spare. |
03-16-2016, 07:40 AM | #3 |
That's your opinion. An opinion with no facts behind it. These trucks have superior engineering through and through, which is why they are still great daily drivers today. The proof is in the pudding. Hundreds of thousands of these trucks, as well as years prior, with tank in same location. Where are the stats to back up the unsafe position of the tank? Can't base it on a 40+ year old corroded tank, either. A leaking tank placed anywhere in the vehicle is unsafe. When we choose to drive 40+ year old vehicles we choose to either put them back to proper condition or take our chances.
03-16-2016, 12:21 PM | #4 | |
CCCC 67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison Moved but still in the family 70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350 Recently sent to new homes 72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp |
03-16-2016, 03:31 PM | #5 |
Gary,
I too have a Four Wheel Camper on my Blazer. I was also stumped as to how I would carry my spare tire, as I don't even have a front mounted spare carrier. I initially used a hitch mounted spare carrier made by Reese, but it ended up being a PITA because I had to remove it to open the camper rear door, and it prevented me from hauling my trailer/boat/etc, because the receiver was being used. I considered modifying the fiberglass half top and rear of camper so I could slide it forward enough to mount my tailgate and use my old swing-away tire carrier. But I didn't want to screw up the camper. So I ended up fabricating a mount for the swing away carrier to attach to, in lieu of the tailgate mounting point. It allows me to use the swing away tire carrier, open the camper door, and keep the hitch available for towing. I did have to make a small cutout in my rear bumper to install the new mounting point, but the new mount is totally removable from the vertically mounted 2" receiver hitch I welded to the frame rail behind the bumper. I also had to make minor modifications to the swing away carrier to make the connection point line up with the frame mounted mount I fabricated. As added precaution to prevent slop between the mount insert and the vertical 2" receiver, I drilled two holes on adjacent sides of the receiver, welded on 3/4" grade 8 nuts, and tighten the two grade 8 bolts through the holes until them are tight against the insert. I will get pictures soon. I am at work and my Blazer is out in then parking lot. Pictures will make more sense. |
03-16-2016, 04:09 PM | #6 |
Pics:
03-16-2016, 04:10 PM | #7 |
More pics:
03-16-2016, 06:30 PM | #8 | |
They were recalled for fuel tanks catching on fire in a side impact collision. The tank behind the seat is yes IMO ****ing stupid. I prefer the look of classics with some modern updates so yes I bought my truck so it's what I do with it, do with yours as you please. Take your "pudding" and give it to somebody else. |
03-16-2016, 06:39 PM | #9 |
Can we get this thread back on track for the sake of the originator? Hotheaded newbie rants will get this thread pulled by the admin. Thanks.
03-16-2016, 06:58 PM | #10 |
03-16-2016, 07:49 PM | #11 |
cleszkie, I was going to do the some thing I have the tire carrier just need the inner brackets for the quarter panel. That looks perfect the way you did it. thanks for help Gary
1972 GMC Jimmy 1/2 4X4 4wheel camper 1970 GMC Jimmy 1/2 4X4 350 1969 Chevy Blazer 1/2 4X4 307 1967 chevy LWB 3/4 396 |
03-16-2016, 08:30 PM | #12 | |
FYI; That recall was for the 1973-87 trucks with the side saddle fuel tanks, not for the cab-mounted tanks in the 67-72 trucks.
Keep your head up...and your stick on the ice. |
03-16-2016, 08:56 PM | #13 |
Keep your original tanks /shrug however keep the thread on topic.
03-16-2016, 09:43 PM | #14 |
My tire carrier is longer and has the jerrycan hook up.
