11-06-2017, 10:47 PM | #1 |
Help with V6 Engine Suffix Codes
Talk about frustrating! Anyone called GM recently? After an hour and a half on the phone with 6 departments I'm no further in my quest than I was earlier. Hopefully someone on this board can help.
I am in the process of building a hot rod 28 roadster. I've decided to use a GM V6 powerplant for a number of reasons. Anyway, I was able to pick up a V6 pretty cheaply. Before putting in the roadster I want to rebuild it. In order to rebuild it I have to identify it so I get the correct parts. Seems simple so far, right? Well, everyone wants the year, make, model and VIN of the donor vehicle. I tried to explain to GM that is what I am calling them for. If I had that, I wouldn't need to be calling. Anyway, the VIN would only be valid IF the engine was the original for that vehicle. So, I'm looking for info from some of you more knowledgeable folks. Here's what I have and am trying to identify: GM V6 4.3 L 4bbl carb Engine ID = T1121UTC Block Cast = 10105867 I know T = Tonawanda Buffalo, NY 1121 = 11/21 It appears to be an 87-91 based on the casting number. Can anyone help identifying this engine further? Thanks in advance. |
11-07-2017, 12:11 AM | #2 |
60-66 Nut
Re: Help with V6 Engine Suffix Codes
I don't know of any sources for 4.3 V6 suffix codes. If you get the casting date off of the block that should be all you need to tell you the date of the engine and then you will know what year range of parts to order. Does this engine have a balance shaft?
11-07-2017, 12:56 AM | #3 |
Here's a little known source for your suffix code.
Appears to be a 1990 motor in a full size type truck. http://www.lmctruck.com/icatalog/cd/full.aspx?Page=9 |
11-07-2017, 08:45 AM | #4 |
Not with a 4barrell. That would be 84-86-ish.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
11-07-2017, 08:45 AM | #5 |
Nicely done, geezer.
Jimmy - another quick sort would be carbureted vs fuel injected. Is your motor TBI? K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
11-07-2017, 08:47 AM | #6 |
Should have stated, what does the casting date day on the intake? I’ve never heard of a carbed motor in 1990. Any competent machine shop should know how to rebuild it.
11-07-2017, 03:48 PM | #7 |
11-07-2017, 05:57 PM | #8 |
I thought the only 4.3L with a carb were in Astro vans and marine powerplants.
Of course the old 229 was carbed.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
11-07-2017, 08:24 PM | #9 |
11-07-2017, 09:06 PM | #10 |
I was working at Oldsmobile at that time. We didn't see many trucks.
But I can't remember ever seeing V6's in square body trucks. Straight 6, yes
11-10-2017, 01:28 AM | #11 |
11-10-2017, 01:57 AM | #12 |
Thanks Geezer. Great find. That said, I found another number cast on the passenger side of the motor beneath 15 layers of paint and crud. That number is K169. That, I interpret to be October 16, 1989. So late 1989 and stamped 1990. TBI most likely removed and carb installed would be my guess. Is my thinking correct? Thanks again everyone...Jimmy
11-10-2017, 09:23 AM | #13 |
Pretty sure marine versions were carbed to the end.
But yes, throttle body injection was used in passenger vehicles 87 and newer
