Old 11-12-2017, 09:53 AM   #1
Husker
Husker's Avatar
250 6 Cyl 2 piece rear main
Is it possible to change rear main seal out while engine still in truck? I have the tranny, bell housing and clutch out. has anyone tried?
thanks
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 11-12-2017, 10:02 AM   #2
YoungPup1977
Re: 250 6 Cyl 2 piece rear main
sure ya can....
you could almost pull the engine for the time it would take under the truck since you have the trans out of it.....plus while its out you could paint the engine Husker Red....GBR !!!!!!
YoungPup1977 is offline   Reply With Quote
Old 11-12-2017, 01:20 PM   #3
Husker
Husker's Avatar
Thanks for replying, I really don't have the room right now to pull engine. it would be Ideal if I could. As far as the Big Red, not doing so good this season.
Ron
Member #111
70 4x4 Project
76 Jeep CJ-5
Thomas Jefferson
Old 11-12-2017, 07:24 PM   #4
Lugnutz65
Lugnutz65's Avatar
thanks
Ron
Husker,
I have done it. You will need to disconnect the front engine mounts and lift the engine about 4", and hold it there. That will allow you to remove the oil pan. Otherwise, the front of the oil pan will not clear the front cross member.
Look carefully at these pictures and you will see a 2X4 that I slipped under the crank pulley. I used a shop floor jack under that 2X4 (maybe a 4X4) to lift the front enough to get the pan out. Remember to "clock" the new seal.
Jay
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 11-12-2017, 07:33 PM   #5
Husker
Husker's Avatar
Thanks Lugnutz you are a True asset, also YoungPup.
Ron
Member #111
70 4x4 Project
76 Jeep CJ-5
Thomas Jefferson
Old 11-12-2017, 08:09 PM   #6
Backpayne
I did the same as Lugnutz. It was a major effing PITA! The rear main seal isn't difficult, but trying to get the oil pan to seal with the 4 piece gasket set was awful. After it leaking twice I used the two log side gaskets and "Right Stuff" gasket maker on front and rear. Worked like a charm.
Backpayne is offline   Reply With Quote
Old 11-12-2017, 08:13 PM   #7
Lugnutz65
Lugnutz65's Avatar
Haha! Yeah, it's wasn't fun. I use RTV like a 2nd grader uses finger paint. I get it all over EVERYTHING. When I was done, it looked like an RTV explosion!
Old 11-12-2017, 08:24 PM   #8
Husker
Husker's Avatar
Did you just leave the old front and rear in place and used Right Stuff over them?
Ron
Member #111
70 4x4 Project
76 Jeep CJ-5
Thomas Jefferson
Old 11-12-2017, 09:14 PM   #9
Backpayne
I only used Right Stuff instead of front and rear rubber gaskets. The rear rubber gasket would never work as it wasn't even the right shape to seal against the rear main cap.
Old 11-12-2017, 09:25 PM   #10
Husker
Husker's Avatar
And it sealed up, Wow. You just filled the Cavity Top and Bottom with RS? How long has it held up? I think mine is leaking from the front Cam/Timing cover.
Member #111
70 4x4 Project
76 Jeep CJ-5
Thomas Jefferson
Old 11-12-2017, 09:29 PM   #11
Backpayne
Ever used Right Stuff? It's expensive for a reason...it is fantastic! It has not leaked 1 drop in mearly a year and a half.
Old 11-12-2017, 09:37 PM   #12
Husker
Husker's Avatar
No I haven't but I know how bad some Rubber seals like mains leak. I will have to try it.
Just fill the void and install the pan?
Thanks again
Ron
Member #111
70 4x4 Project
76 Jeep CJ-5
Thomas Jefferson
Old 11-12-2017, 10:15 PM   #13
Husker
Husker's Avatar
Thanks fellas
Ron
Member #111
70 4x4 Project
76 Jeep CJ-5
Thomas Jefferson
Old 11-13-2017, 06:46 AM   #14
GRX
GRX's Avatar
Great advice thus far. With puctures no less. Members here are indeed a real asset.
Would like to add that a piece of stout copper wire is nice for pushing the old seal out.
Apply a thin film of RTV to the main cap to prevent seepage between that and block. Some people like to install the seal offset slightly so the ends don't line up with block & cap.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
