Closed Thread
Old 01-17-2011, 08:10 PM   #1
lolife99
Old Guy
lolife99's Avatar
"Drum to Disc" conversions 60-70
60-62 truck with:
63-70 Crossmember Installed
60-62 Truck with:
71-72 Crossmember Installed
60-62 Truck with:
73-87 Crossmember Installed
60-62 Truck with:
71-72 Crossmember Not Yet Installed:
60-62 Truck with:
73-87 Crossmember Not Yet Installed:
63-66 truck with:
63-66 Crossmember Installed
63-66 truck with:
63-66 truck with:
63-66 truck with:
63-66 truck with:
67-70 truck with:
67-70 Crossmember Installed
67-70 truck with:
67-70 truck with:
67-70 truck with:
67-70 truck with:
60-72 truck with
"Unknown" Crossmember Swap?
* This is where it's hard to determine the correct parts needed.
Here's the break down by year:
Disc Brake Spindle:
*60-70 (Aftermarket Conversion Spindles)
*71-72 (oem or drop)
*73-87 (oem or drop)
C10
Grouped by Differences:
*60-62
*63-70
*71-72
*73-87 (HD 1.25" wide rotors)
*81-87 (LD 1.00" wide rotors)
**Some 81-87 trucks also had the HD rotors**
** All Aftermarket 6-lug "Conversion Rotors Are the HD 1.25" wide version**
C20
*71-87
Rotors:
*71-72 (1.25" wide)
Calipers:
*71-72 (1.25" wide)
Upper Ball Joint:
C10
*60-62
*63-70
*71-72
*73-87
C20
*71-87
Lower Ball Joint:
C10
*60-62
*63-70
*71-87
C20
*71-87
Control Arm Upper Cross Shafts:
C10
*60-62
*63-72
*73-87
C20
*63-87
Control Arm Lower Cross Shafts:
C10
*60-62
*63-72
*73-87
C20
*67-86
Inner Tie Rods:
C10
*60-62
*63-64
*65-70
*71-72
*73-87
C20
*60-64 (drivers side)
*60-64 (pass. side)
*65-70
*71-87
Outer Tie Rods:
C10
*60-64
*65-70
*71-72
*73-87
C20
*60-64
*65-70
*71-87
Tie Rod Adjusting Sleeves
C10 and C20
*60-64
*65-70 (5/8" thread)
*71-87 (11/16" thread)
Centerlink:
*60-62
*63-64
*65-70
*71-72
*73-87
Pitman Arm:
Grouped by differences:
C10
*60-66 Manual
*60-66 P/S
*67-72 Manual
*67-87 P/S (Specify Year When Ordering)
C20
manual:
*60-66
*67-68
*69-70
*71-87
Power Steering:
*69-70
*71-87
Idler Arm
C10
*60-62
*63-66
*67-82
*83-87
C20
*60-66
*67-82
*83-87
Steering Box:
Manual
*60-62
*63-66
*67-82
*83-87
Power Steering
Keith
Convert to disc brakes.
WTB: Radio Delete Plates and clips.
lolife99 is offline
Closed Thread
Copyright ©2000 - 2020, vBulletin Solutions Inc.
