Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 07-14-2012, 01:33 PM   #1
Fords72ChevyC10
Starter Solenoid Wiring Help!!!
Ok, this is what I'm working with.
72 Chevy C10 with an 80s 350 (center bolt valve covers). I replaced the chopped up wiring harness with the one available from Painless. I have everything wired up but the starter does not engage.
The PO converted to an HEI ignition system and the starter solenoid has 3 terminals; battery terminal, R terminal and the S terminal. Originally I connected the pink wire to the HEI, the purple wire to the S terminal, and the red wire to the battery terminal as per my understanding of the instructions.
But the starter did not engage and it did not seem correct that nothing would be connected to the R terminal.
So here is what I am thinking should be done, the pink wire needs to be connected to the R terminal with a wire spliced into it that runs up to the HEI. Is my thinking correct?
If not what is the problem with the original set up that it did not work?
My understanding is that even if the HEI system is not getting power the starter should turn over but its not.
Thanks for the help.
1972 Chevy C10 aka Sancha
Fords72ChevyC10 is offline   Reply With Quote
Old 07-14-2012, 01:39 PM   #2
Fords72ChevyC10
Re: Starter Solenoid Wiring Help!!!
And if anyone is interested and lives in the hi-desert region of California and willing to travel to FT Irwin to help a guy rewire his truck, that would be helpful.
Old 07-14-2012, 01:51 PM   #3
Fords72ChevyC10
I also used a bypass wire to connect the neutral safety switch until I can find it.
Old 07-14-2012, 02:46 PM   #4
fixit-p
fixit-p's Avatar
Purple wire to the S terminal is all you need (besides power and ground from battery). The HEI does not need to connect to the starter, verify that you have power to the S terminal with key in start position, if you have a multimeter you can also do a voltage drop test on the battery cables.
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 07-14-2012, 09:04 PM   #5
Fords72ChevyC10
That is how I originally had it set up but the starter would not engage and turn the engine over. I am lost as what to do next.
Old 07-14-2012, 09:22 PM   #6
fleetsidelarry
Senior Car Nut
fleetsidelarry's Avatar
did you remember the short jumper wire that goes from the s terminal on the OEM solenoid to the batt terminal?
Larry
fleetsidelarry is offline   Reply With Quote
Old 07-14-2012, 10:50 PM   #7
fleetsidelarry
Senior Car Nut
sorry, disregard, for some reason I was thinking you had a remote solenoid. are you certain the purple wire gets current when the switch is turned to start?
Larry
Old 07-15-2012, 12:19 AM   #8
Fords72ChevyC10
No, I am not positive. That is something I need to check.
If it is not getting power what would cause this?
Old 07-15-2012, 03:45 AM   #9
FLEET72
FLEET72's Avatar
Starting from the source, ignition switch. Red is the 12V supply and purple is where you should find 12V when the key is in the start position. If there is no power there, bad connection or bad switch.
I see you had this covered If you have an automatic, make sure the neutral safety switch is in park or neutral. Confirm this with 12V on both terminals.
Then on to the bulkhead connector. Make sure that neither wire has been pushed out or loosened. And then finally to the starter solenoid.
Oscar
'72 Shortbed Fleetside
'95 Jimmy 4X4
'69 GMC Custom Camper
FLEET72 is offline   Reply With Quote
Old 07-15-2012, 08:32 AM   #10
fleetsidelarry
Senior Car Nut
this bypass wire runs from where to where? (I'm assuming the "IT" in your post above is the non-start problem, not the NS switch)
I'm not understanding what you would have bypassed.
Larry
Old 07-15-2012, 10:17 AM   #11
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Here's the neutral start switch on top of the blue steering column. The purple wires come from the key switch and go to the starter solenoid. If you pull the plug off the NSS and jump the two purple wires then you are by passing the neutral start switch. The truck will start in gear so be careful.
This is the starter wiring circuit.
To isolate the starter from the purple wire, I take the purple wire off the S terminal and jump across the solenoid between the battery cable terminal and the S terminal. I use an old screwdriver or wrench because it will arc. leave the nut on the S terminal to avoid messing up the threads.
If the starter turns then the problem is in the key switch to the S terminal wiring. If it doesn't then it's in the starter. Make sure the truck is in Park so it won't move and leave the key off so it won't start. The plate in this picture is for a remote solenoid so disregard it.
Here's abetter picture.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 07-15-2012, 12:42 PM   #12
Fords72ChevyC10
Thanks guys for helping me out in this endeavor, I am going to work on this today so hopefully I get it working.
Old 07-15-2012, 02:56 PM   #13
Fords72ChevyC10
This is what I found out so far,
The purple wire is getting power when I try starting it, so it must be the solenoid. I tried tapping it when someone was trying to start it but to no avail.
Old 07-15-2012, 03:28 PM   #14
fixit-p
fixit-p's Avatar
Battery cables. Do yo have a voltmeter.
Old 07-04-2016, 10:51 PM   #15
jrny99
thank you for who ever put the idea that it might be neutral safety switch, i install a floor shift in my auto and did not jumper out this purple wired switch. worked like a charm once i jumpered it.
jrny99 is offline   Reply With Quote
Old 07-04-2016, 10:53 PM   #16
jrny99
thank you for this post, saved me having to light my truck on fire and burn it to the ground. : )
Attachment 956534
Attachment 956535
Attachment 956536
Attachment 956537
