Old 08-11-2017, 01:24 PM   #1
allytle
10 Bolt Rear End
I haven't been able to find any info on my rear end. Anyone have and links to charts to help? Thank you!
allytle is offline   Reply With Quote
Old 08-11-2017, 03:01 PM   #2
b454rat
Re: 10 Bolt Rear End
Well it's not a 10 bolt. It's an Eaton but not sure which model. Try google 1964 Eaton axle. There are I believe 2 models...
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 6” lift
1999 GMC Yukon 350/4L60 4" SAS
Old 08-11-2017, 05:29 PM   #3
allytle
I counted the bolts around the back and assumed it was a 10 bolt since it had 10 bolts. hahaha! That's what I get for thinking it was that simple. Thanks for the help. I'll check it out.
Old 08-11-2017, 06:07 PM   #4
Clyde65
Clyde65's Avatar
Probably an Eaton HO33 if 1/2 ton, not the most desirable and parts can be scarce and spendy
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 08-11-2017, 07:09 PM   #5
allytle
It's a 3/4 ton. I'm trying to decide if I'm keeping it before I do brakes and stuff.
Old 08-11-2017, 09:39 PM   #6
Clyde65
Clyde65's Avatar
HO-52 then.
http://6066gmcclub.com/archive/index.php/t-47314.html
If you can, swap out to a FF 14bolt from a GM or Dodge truck. Got disc brakes and ready parts availability.
Good luck!
Clyde65
Rebuild of Clyde
support our troops!
Old 08-12-2017, 12:20 AM   #7
allytle
HO-52 then.
Good luck!
Thank you sir. I'm going to try and do that. My buddy's got a tow yard I can pick through. I was getting ready to order brake parts for this and thought I better check into it first. Glad I did.
Old 08-17-2017, 10:44 AM   #8
68Gold/white
Knowing nothing about your potential build, or you...have you thought about converting it to a 1/2 ton? That might be easier....parts would be common..
68Gold/white is online now   Reply With Quote
