05-19-2019, 09:29 AM | #1 |
Qjet base plate repair
https://youtu.be/R86zI4ii0nk
I thought I would share this as to how to repair a worn out throttle shaft bore in a quadrajet carburetor base plate. Finding a worn out bore has put my rebuild on hold for a bit. |
05-19-2019, 12:27 PM | #2 |
Re: Qjet base plate repair
I've watched a couple of his video's, he does a good job.
If you don't want to wait, Summit Racing has "remanufactured" QJets, long as you have a rebuildable core to send back. Summit Racing QJet: https://www.summitracing.com/parts/sum-250200 Jet also makes them. Not sure if one is better than the other, Jet are more expensive. I have 2 QJets that I'm either going to rebuild or go the Summit Racing way. |
05-19-2019, 01:35 PM | #3 |
The fun is in DIY but this one sure does seem a lot more complicated than the Holley I did so many years ago. Tomorrow I'll see if I can find a reamer that costs less than a carb.
05-19-2019, 03:56 PM | #4 |
Yeah, I hear ya. I've rebuilt a couple of QJets. I have several sets of secondary needles that I play with. They are stamped and I looked up the stampings and put the middle of the pack for Wide Open Throttle (WOT) and it ran pretty fast up into the higher range. Got pulled over by a CHP upon doing so. LOL. I wish I had a reamer to loan you. I haven't had to do that.....yet.
05-19-2019, 04:14 PM | #5 |
Here's a kit from Quadrajetpower.com: https://quadrajetpower.com/primary-s...shings-screws/
05-20-2019, 12:00 AM | #6 |
You might want to look at Lars Grimsrudīs paper on QJetīs works great.
do a google. |
05-20-2019, 12:26 AM | #7 | |
05-22-2019, 08:05 PM | #8 |
Scrapper 1
what you need a base plate I can look to see if i have a few extra's I like to see a pic of what your looking at and i will see if i can match it I'm In Calif so are stuff here is a lot better then other places in the country
05-24-2019, 06:02 AM | #9 |
Thanks for the offer but since posting I took another look at it and decided it isn't that bad and will use it as is. I found one bent needle metering rod and one plugged jet. The float pintle also had a big groove around the rubber part which could explain all the gas in the oil. It is now back together with only the choke to put on..
