Old 09-12-2017, 04:31 PM   #1
Blue18
straight 6 intake exhaust clamp?
Im missing an exhaust /intake bolt with this piece on it that holds intake and exhaust manifold to the head. cant find it anywhere. It came off a 1968 c10 4.1l 250
Blue18 is offline   Reply With Quote
Old 09-12-2017, 04:42 PM   #2
GRX
GRX's Avatar
Re: straight 6 intake exhaust clamp?
If you cannot find any, one can be made from a piece of 1/2" thick bar stock. Max torque on those is only 30 lb-ft. Have done it more than once.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 09-12-2017, 04:44 PM   #3
Blue18
i do not have have many tools to cut metal but do i use solid or hollow bar stock?
Old 09-12-2017, 04:48 PM   #4
Blue18
Does anyone know what it called?
Old 09-12-2017, 06:29 PM   #5
RichardJ
Do you have all the clamps except one long style? below are a couple of old threads about the clamps. I wouldn't bother replacing any of the missing bolts. NAPA should have studs that fit for a much easier installation. There should be two studs now in the 3rd hole, in from each end. Head rebuilders often remove them and don't replace.
http://67-72chevytrucks.com/vboard/s...d.php?t=374618
http://67-72chevytrucks.com/vboard/s...d.php?t=454785
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 09-12-2017, 07:21 PM   #6
'68OrangeSunshine
'68OrangeSunshine's Avatar
L6 Manifold Clamping Bars.
Old 09-13-2017, 01:32 AM   #7
Blue18
Thanks to all I'm fabbing some 1/2 inch. Figured I could test my skills
Old 09-16-2017, 05:17 AM   #8
Blue18
thanks for the help guys get her fixed up and sounding normal again !
Old 09-17-2017, 03:45 PM   #9
scooterpimp
scooterpimp's Avatar
Maybe use an old chevy rocker arm flipped backward?
scooterpimp is offline   Reply With Quote
Old 09-17-2017, 08:02 PM   #10
'68OrangeSunshine
I have used the high-grade alloy steel pivot ball -- flipped around -- to secure the end bolts on L6 headers. Studs hold the stock manifold in that set up.
