Old 11-09-2017, 03:03 PM   #1
nikwho
nikwho's Avatar
What oil viscosity in fresh SBC in cold weather?
Hello all,
I'm curious what viscosity oil I should run in my freshly rebuilt gen 1 350 SBC? It's got just half an hour run time to break in the cam. All bearing clearances are roughly 0.002". I live in the mountains, where it gets fairly cold in the winter. Periodically down to 0°f but I only drive this truck on nicer (relatively) days. I was planning on running 10w30 VR1 Valvoline racing oil. Has a Melling high volume pump. Stock bottom end w/ Summit 1103 cam and LT1 305 cylinder heads. Weiand Streel Warrior dual plane manifold with 1406 Edelbrock carb.
Thanks for any help!
Nik
'59 Apache - 383" SBC/TH-350
'68 GMC - BBC/TH400
nikwho is offline   Reply With Quote
Old 11-09-2017, 03:48 PM   #2
6768chevylover
6768chevylover's Avatar
Re: What oil viscosity in fresh SBC in cold weather?
You could run 20w50 with a zinc additive or can use Valvoline vr1 20w50 if you want the zinc already without adding the additive. I run either one with hot temps or cold temps.
6768chevylover is offline   Reply With Quote
Old 11-09-2017, 04:09 PM   #3
Killer Bee
Killer Bee's Avatar
you're on the right track for break-in and weight.. heavier oil for heat, light oil for cold..
also mind the tight engine and high output pump.. heavy oil may build too much pressure..
try searching sbc break in oil and several engine builder threads on various forums will pop up..
if you had a local shop do the engine work, ask them what they recommend for your climate..
or consult manufacturer's recommendations of the components you used in your build..
good luck!
Old 11-09-2017, 07:08 PM   #4
cadillac_al
Your oil pressure is going to be pretty high with a new tight engine. If you don't like seeing you roil pressure gauge pegged you should stay with 10w30 and see how you like it. I'm going to try 5w30 this year. My mains are at .003" and the oil pump is supposed to be a stock oil pump but I have my doubts. My pressure is always very high when cold and never gets below 30psi at idle when hot. If the pressure gets too high when cold it will bypass the filter which isn't good.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 11-09-2017, 10:17 PM   #5
Alex V.
Alex V.'s Avatar
Unless you're using it very hard for some duration anything thicker than 10w40 is unnecessary. If I was gonna put 5w30 in any small block it'd be something like your scenario - fresh engine, cool weather, gentle use. The high volume pump should make it even safer to use thinner oil as it'll further guarantee good supply.
Alex V.
1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs.
1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue.
Alex V. is offline   Reply With Quote
Old 11-10-2017, 12:13 AM   #6
Captainfab
60-66 Nut
I would go with 10W30 as well and see how it does. If the pressure is too high when cold, consider going with 5W30.
Old 11-10-2017, 11:12 AM   #7
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
10w30 will work in dang near any conditions. Heck even newer rigs with tighter tolerances run 5w30.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 11-11-2017, 10:23 AM   #8
truckdude239
truckdude239's Avatar
Id try 10w30 or 5w30 i use to run 20w50 and man my truck was hard to start when ti was 20 degrees outside and would peg the gauge out
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
