Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 04-24-2018, 09:20 PM   #351
gringoloco
A guy with a truck
gringoloco's Avatar
Re: Ratchet's Blazer - 1970 2wd with Original paint
Warning, non-slip rear end! This thing is sofa king badass
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass
gringoloco is online now   Reply With Quote
Old 04-25-2018, 09:24 AM   #352
smbrouss70
smbrouss70's Avatar
One of the previous owners felt the need to label everything on the dash. I haven't been able to pull them all off since its a part of its character.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2012 Chevy Tahoe LT "Powdered Sugar"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 05-17-2018, 11:34 PM   #353
smbrouss70
smbrouss70's Avatar
Just realized that I hadn't put any pictures on here for a while.
I've gotten the Captainfab brackets and hydroboost mounted up. The brackets do a good job of hiding the mess on the firewall from old leaking master cylinders. I tried putting a vacuum booster to save myself some time of having to deal with power steering hoses, but was having issues with connecting the brake pedal to the booster, so I switched back to the hydroboost. I have some factory style lines for an 86 3/4 Ton for the hydroboost, but it turns out that they hit the proportioning valve. I ordered some PTFE AN hoses and ends this week and they should be in by Friday when I get home from TX, so HOPEFULLY, I can finally finish the brakes this weekend!
The other 2 pics are of my surprise visitor that was on the handle of the flaring tool that I grabbed before I noticed him! This was not long after I had a Brown Recluse crawl in between my legs, and after I tested the surface tension of the skin on my finger with a hacksaw blade... Hopefully, I'll get it together AND still be alive by the time HRPT gets here!
Steven
R.I.P. Oscar
Shop Build
Old 05-18-2018, 12:23 AM   #354
Advanced Design
Advanced Design's Avatar
Holy snakes Batman! What kind is that? Had one in my shop a couple years ago acting if he owned the place. A bit startling.
Advanced Design is offline   Reply With Quote
Old 05-18-2018, 01:05 AM   #355
smbrouss70
smbrouss70's Avatar
No clue, I wasn't able to find anything quite like it on the internet. Probably a little rat snake of some kind. I do know that I didn't like him and he didn't like me!
Steven
R.I.P. Oscar
Shop Build
Old 05-26-2018, 03:16 PM   #356
smbrouss70
smbrouss70's Avatar
Last weekend, my buddy Chris came over to help me make some pretty brake lines to drop down to the frame rail from the prop valve. I'd say we nailed what I was looking to do.
Steven
R.I.P. Oscar
Shop Build
Old 05-26-2018, 03:21 PM   #357
smbrouss70
smbrouss70's Avatar
Last night and this morning, I started the tedious task of cutting down my wheel studs and assembling the billet hubs from Kore3. Spindles have been cut down, smoothed out and painted, so now I just need to pack the bearings and install them and I can finally finish mounting up the front brakes. Now that I'm done with lunch, I'll head back out there and get that done.
Steven
R.I.P. Oscar
Shop Build
Old 05-26-2018, 05:08 PM   #358
So you think it will be done, so you can get a good night sleep before you have to head out for PowerTour?
1981 GMC High Sierra SWB Stepside
"Whitey" 2002 Chevy Silverado 1500 SWB W/T
Board Vendors
Old 05-26-2018, 05:19 PM   #359
smbrouss70
smbrouss70's Avatar
Hopefully I'll get it done in time to leave for HRPT on June 7th. If I can make it to the starting line in Bowling Green, I will acquire a passenger/driver and sleep then...
Steven
R.I.P. Oscar
Shop Build
Old 05-27-2018, 08:16 PM   #360
smbrouss70
smbrouss70's Avatar
Ran into an issue last night with the pad abutment bracket contacting the rotor. Fortunately, I know some awesome guys, so I had some spacers machined to fix the problem!
I have washers stacked holding that black pad abutment bracket in the correct position, but here's a pic of the spacers that Chris made for me that I am about to go pick up. These freakin' rotors are huge!
I couldn't figure out why my panhard bar adjustment changed after I put in the pinion shims to raise the pinion 3 degrees, until today. After moving the axle back and adding the pinion shims, my diff cover actually hit the panhard bar and tweaked it a bit. So I ripped it out and stole the No Limit panhard bar off of my other truck. I've got it most of the way in and it looks like it is going to work, and as an added benefit, the bar is much more level at ride height. I'll get some pics of it later.
Steven
R.I.P. Oscar
Shop Build
Old 05-28-2018, 12:56 AM   #361
gringoloco
A guy with a truck
gringoloco's Avatar
That’s a little more than the shim mine required. Glad you got it sorted. Is that the 13.4 or 14” rotor?
-Chris
Old 05-28-2018, 01:57 AM   #362
smbrouss70
smbrouss70's Avatar
That picture makes the spacers look bigger than they are, they are only 3/16" thick. Those are the 14" Z06 rotors. It's Kore3's "Hybrid" setup. It uses a different bracket to move the 2 piston calipers out to fit on the 14" rotor.
Steven
R.I.P. Oscar
Shop Build
Old 05-28-2018, 10:38 PM   #363
gringoloco
A guy with a truck
gringoloco's Avatar
Very nice. I’ve contemplated moving up to the 14” z06 front/13” z51 rear when its time for rotors.
Done yet?
-Chris
Old 05-28-2018, 11:02 PM   #364
smbrouss70
smbrouss70's Avatar
Fronts are all put together for the last time... at least. I finished up what I had left to do on the No Limit panhard bar, which included a lot of cutting, re-drilling, and re painting. Apparently the back of a 2wd Blazer frame is not exactly like a SWB truck. I've bent up 2 sets of brake lines for the rear axle and I'm still not happy with them. That might have to end up on the re-do list for this winter.
I have to leave for TX in the morning and won't be back until Friday night. I'm hoping to get a lot of sleep while I'm stuck in TX, because I won't have time for sleep next weekend.
Steven
R.I.P. Oscar
Shop Build
Old 05-29-2018, 04:18 PM   #365
gringoloco
A guy with a truck
gringoloco's Avatar
Function over form! Any projects you can take with and pre-assemble in the hotel room? I once painted a console on a hotel room balcony. Bet the over-spray is still there
-Chris
Old 05-29-2018, 04:29 PM   #366
smbrouss70
smbrouss70's Avatar
I do still need to repaint the console!
Steven
R.I.P. Oscar
Shop Build
Old 06-03-2018, 03:57 PM   #367
smbrouss70
smbrouss70's Avatar
I feel like I am going backwards...
Steven
R.I.P. Oscar
Shop Build
Old 06-03-2018, 06:13 PM   #368
Now what?
Board Vendors
Old 06-03-2018, 08:32 PM   #369
smbrouss70
smbrouss70's Avatar
Oh, just the fact that I'm running out of time and it seems like I am taking more stuff apart than what is going back together.
Steven
R.I.P. Oscar
Shop Build
Old 06-03-2018, 09:52 PM   #370
gringoloco
A guy with a truck
gringoloco's Avatar
I see brakes front and rear. Just needs to go, steer, and stop. All else are luxuries
-Chris
Old 06-03-2018, 11:19 PM   #371
smbrouss70
smbrouss70's Avatar
I'll remind you that you said that when we are sweating our butts off!
Steven
R.I.P. Oscar
Shop Build
Old 06-04-2018, 07:00 PM   #372
gringoloco
A guy with a truck
gringoloco's Avatar
I could stand to sweat off some of this waistline
-Chris
Old 06-04-2018, 07:29 PM   #373
smbrouss70
smbrouss70's Avatar
You and me both, brother.
Steven
R.I.P. Oscar
Shop Build
Copyright ©2000 - 2018, vBulletin Solutions Inc.
