12-17-2018, 11:34 PM | #1 |
Overdrive Cable/Kickdown Switch Placement
Looking for the proper placement under the dash for the overdrive cable bracket and where the cable goes thru the firewall.
Also where does the kickdown switch mount on a 292? As usual, pictures and links are great. Thanks.
72 C20 292 3OTT 77 GMC 2500 4x4 Longstepper 350 4sp 50 3100 ex Airforce/Town of Mendon fire truck 72 GMC 1500 2wd short stepside 250 4sp 78 GMC 2500 4x Longstepper 292 4sp 54 6400 Chevy 5 window 4 sp 2sp vac rear end Shell oil truck/dump truck (Norman) |
12-18-2018, 12:31 PM | #2 |
Re: Overdrive Cable/Kickdown Switch Placement
I can't answer the overdrive cable placement as I've never actually seen a factory install 67-69. If your truck is a 71-72 A good option for the kickdown switch would be to locate the pedal switch from a 71-72 Turbo 400 automatic truck. It's mounted inside the truck at the throttle bracket. Should work perfect for what you're trying to do.
Steve weim55 Colorado Last edited by weim55; 12-18-2018 at 12:46 PM. |
12-18-2018, 04:35 PM | #3 |
Thanks, I'll check it out.
