01-12-2018, 12:32 AM | #1 |
Idea for headliner backer board
I am working on a 1986 K10 stepside for my son. There is no headliner or backer board. I know I can buy a ABS backer board from Brothers for about $200. However, my son and I are project oriented and thought about making our own.
What are everyone's thoughts about layering press and seal plastic wrap across the ceiling with excess over lapping the edges or where the headliner would stop. Then adding a layer of fiberglass to create a form. Does anyone think it would stay in place long enough to harden? I was thinking of trying it. I would then trim the edges and drop it down. Could put it on a table top and add a second layer of fiberglass. |
01-12-2018, 06:10 AM | #2 |
Re: Idea for headliner backer board
If you were to buy one, I would go with
https://www.usa1industries.com/headliners/ They are a bit cheaper and close to you, being in NC and your in Alabama. Brothers is notorious for taking forever to ship something. But, anything is possible. Sounds a lot of work. I would be afraid of it not working and then you would have a mess on the ceiling of the truck. Have you tried finding one in a salvage yard and then recovering it with new headliner fabric? I was able to use mine, even though the edges under the visors were a little brittle. Turned out great!!
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR Last edited by TKCR; 01-12-2018 at 06:28 AM. |
01-12-2018, 06:19 AM | #3 | |
I am open to ideas. I know this topic has been covered many times in different threads. I am just trying to think outside the box. Not being cheap. It's not a cost issue. We just like to be creative. As for Brothers....I've never had anything shipped. I used to live down the street from their facility when I was restoring my 69 C-10 so I used them often for parts local pick up. |
01-12-2018, 06:31 AM | #4 | |
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
01-12-2018, 09:03 AM | #5 |
I have used the very same idea when rebuilding door panels and head liners for other cars - non chevies - but the process is exactly the same. In my case, I used MAS epoxies because it is a lot more environmentally friendly than polyester resins are. There are no Volatile Organic Compounds (VOCs) with MAS brand epoxies. The VOCs are what cause the problems with disposing of the excess, can cause alergic skin reactions, force you to wear a respirator and so forth.
And here is a quick lesson from a guy who has done TONS of fiberglass epoxy work. (...hence my name "Woodyboat") We call factory built fiberglass boats "FRP" because it is easier to spell on a forum than to type out "Fiberglass Reinforced Plastic." But this distinction needs to be made between FRP fiberglass and epoxy fiberglass. FRP glass is polyester based and it's the mainstay of the professional boatbuilding industry. It's ok and it's cheap but has lots of VOCs. You can buy little kits at Autozone and Advance. But polyester does not bond well with wood or paper products. It will hold for a while - a few years or so - but in time, will let loose and delaminate. The boat building industry uses a lot of wood in their FRP boats and then when the glass and woods delaminate, they blame it on the wood instead of putting the blame where it really should be - on the polyester. You will hear a lot of talk in the boatbuilding industry about how wood always rots and that is just complete nonsense. The polyester first delaminates from the wood, moisture gets in and YES it does rot. But if epoxy were used in the first place, there would never be any delamination and thus, no moisture could ever get in. Get it? On the other hand, epoxy bonds very well with wood, paper and masonite and will far outlast the vehicle. ... the owner, the owner's grandkids and so on. Epoxies have revolutionized the wooden boat building hobby and fine mahogany runabouts become family heirlooms with no neglible wear for decades when cared for correctly. When building headliners, I use either masonite or luan if I'm starting from scratch to build a new one. I will usually plan on two coats because sometimes quite a bit of the epoxy can be absorbed into the luan but that's ok. Think of it as a primer coat and keep working. As the catalyst kicks off, the stuff will go through a tacky phase within a few hours and that's when it's ready for the next coat. Cure times are rather slow and that's what you want, especially if it's your fist time. So don't panic if you come back the following morning after a night of mixing and applying and it's not ready to sand. You will want to keep applying more coats as long as the texture of the fiberglass mat can be seen or felt. Of course, when the epoxy is completely cured, it can be sanded smooth with a D.A. sander. Sanding and cutting is the only time you should need some sort of dust mask. I would not try to epoxy the project with the headliner up in place. Rather, when I do one, I estimate the bend and curvature and work that out on a big table with plenty of cardboard down to collect drips. There is a certain amount of give to it. If you get close, it should fit. If you build the thing oversize, you can always cut it to shape with a cutting wheel. If you cut too much off of it, you can always epoxy the boo boo right back or add more glass cloth and luan - whatever you need to do. It's darn near foolproof. You will want to watch your temperatures and choose the correct catalyst for the temps in your garage. If your catalyst calls for 90 degrees and it's 50 degrees in the shop, it might be a very long time kicking off. On the other hand, if it's 90 degrees and you're using a 50 degree kicker, you had better be ready to work super fast. LOL, it's not important how I know that. Get plenty of nitrile gloves and use acetone to clean up messes. If I'm repairing an old door panel or headliner, I simply make sure that the backer board is as clean as I can get it and completely dry. I will always use some fiberglass mat. It only makes sense. Also, I use ONLY MAS brand epoxies because of their not having any VOCs. A boatbuilding friend has had such severe allergic reactions to VOCs that he has been hospitalized after glassing the hull on his boat. He switched to MAS when he helped me with one of my boats and has never looked back. But MAS is rather pricey and that's the trade-off. If you want to really do something up that is completely your own design and are willing to pay a little more, then there is no better solution than MAS. It is the Mercedes of epoxies. I love the stuff. Of course, all my custom car buddies think that all of this is WAY overkill for headliners and such but I'm ok with that. Better too much than too little. Last edited by Woodyboat; 01-12-2018 at 09:25 AM. |
01-12-2018, 12:05 PM | #6 |
Why not just glue to roof with no board, that is what I did. The spray adhesive worked great
79 Chevy 2wd BIG10 350 TH400 |
01-12-2018, 12:30 PM | #7 |
Welcome, neighbor!
Have you checked with Captkaos yet? He's a member here and also runs www.73-87chevytrucks.com website and store. He is local and can probably get you a headliner. Shoot him a message here: http://67-72chevytrucks.com/vboard/member.php?u=78 or here: mail--webmaster@73-87ChevyTrucks.com Phone--205-202-0875 Hours--Monday - Friday 9am to 5pm Central Time Mail--3298 Pike Ave Birmingham, AL 35224 |
01-12-2018, 03:26 PM | #8 |
That is certainly one option but that would miss the point of this thread completely. The desire is to custom build a headliner - one that can be removed and replaced, can be modified, can incorporate lots of various other ideas such as lighting, Lizard Skin or Dynamat... it goes on and on.
01-13-2018, 01:48 AM | #9 | |
It's an expanded PVC sheet material. We use it in a broad array of applications. It comes in a variety of colors and thicknesses. It is easily cut, shaped, formed, glued, painted, etc. It's water resistant. I makes an excellent backer for custom upholstery on door panels for instance (much better than MDF panels)... It's very light weight, yet strong. It's a lot easier, more forgiving, less expensive, and a lot cleaner to use than fiberglass. It's readily available and comes in 4' x 8' and 5' x 10' sheets, as well as smaller sizes. Some suppliers will even cut the sheets down for you. Give it looksee and you might be surprised. I have some small samples laying around and could send you a piece if you want. Send me a PM if you are interested. More info. . . http://www.tri-dee.com/Sintra%20shee...nformation.htm These guys are about an hour from you. . . (334)262-0703 577 Trade Center Street Montgomery, AL 36108-2107 http://www.farcoplastics.com/product...5BPVC+FOAM%5D+ More info. . . https://www.piedmontplastics.com/pro...pvc-foam-sheet
--Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...d.php?t=655783 --Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...ghlight=Belair "Life is tough - wear a cup!" "Old Enough to Know Better - Too Young to Resist" "Junk is something you will need three weeks after you throw it away." Last edited by Super_Dave; 01-13-2018 at 01:57 AM. |
