Old 09-11-2019, 01:00 PM   #1
jmon1123
Oil confusion, please help!
Hey all, I recently got a Ď69 long step, from the forest service up in wahington.
I will try to post photos later, but onto my question. in it, is itís factory 292 with the granny 4speed. I want to do an oil change and shang the sparks, but iím confused on what oil to use. Iím seeing so many different claims saying you need this additive or that additive. Iím in oregon and the temperature is getting down to the low 50s. If anyone has a solid answer it would be greatly appreciated. Thanks!
'76 Orange and White C10 Bonanza
Ď69 Forest service C20 (current)
jmon1123 is offline   Reply With Quote
Old 09-11-2019, 01:47 PM   #2
Mts67C10K20
Active Member
Mts67C10K20's Avatar
Re: Oil confusion, please help!
Here in Michigan I've always run 10w40 conventional oil
In my flat tappet cam engines
The article below is a good read on oil difference
Engine Oil Testing Results | The De Tomaso Forums
https://pantera.infopop.cc/topic/eng...esting-results
Mts67C10K20 is offline   Reply With Quote
Old 09-11-2019, 02:01 PM   #3
67C10Step
67C10Step's Avatar
I did the same as you back in May when I got my 67 with 283. After much reading and consideration I went and grabbed up five quarts of the Valvoline VR1 conventional racing oil. Looked at the Lucas additive as I am a big Lucas fan but decided to just go with a good oil that I did not have concerns using.
67C10Step is offline   Reply With Quote
Old 09-11-2019, 03:31 PM   #4
'68OrangeSunshine
'68OrangeSunshine's Avatar
I run SAE 30 weight in my 292s.
Old 09-11-2019, 03:44 PM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Any 10w30 will do. You can also add zinc additive (ZDDP).
I live up in the northwest corner of WA State and I use 10w30 in all my older rigs.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 09-11-2019, 03:44 PM   #6
bigmac73
bigmac73's Avatar
for my flat tappet cammed engine I run Rotella conventional 10-30w
always hear it still had a zinc content .But I do not know for sure just never had any issues
Mike
72 C-10 Cheyenne PS/PB/Tilt/Tach/Rear slider/
385HP/405TQ Vortec 355 /TH350 2200RPM Stall
MSD Ignition/Holley 650 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 09-11-2019, 04:32 PM   #7
HO455
HO455's Avatar
Howdy neighbor.
I run Royal Purple HPS 10/30 in my daily driver Burban. High zinc so no additional additives needed. I usually get it through Jegs or Summit, but it is available locally through Baxter Auto parts.
And its on sale now. See below.
https://www.summitracing.com/parts/r...yABEgKWn_D_BwE
1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F3 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo
The WMB http://67-72chevytrucks.com/vboard/s...d.php?t=698377
Old 09-11-2019, 04:59 PM   #8
garyd1961
Rotella took the zinc out a few years ago.
garyd1961 is offline   Reply With Quote
Old 09-11-2019, 07:43 PM   #9
Furno68C20
you have to be careful and do research on your engine components. Oil's have changed, I just checked my dipstick and it was full of metal. Unknow to me, the cam I have is a flat tappet and was using just conventional 10w30 and the oil is nasty and dirty after not even 200 miles. Just bought hi zink Lucas Hot rod oil and hopefully the 327 will like it better. Hope the Cam isn't too worn down.
Furno68C20 is offline   Reply With Quote
Old 09-11-2019, 08:49 PM   #10
rsavage
rsavage's Avatar
Brad Penn Penn Grade - you can buy it from Summit if it is not available in your area. Only oil I will use in classic flat tappet engines.
1961 C1 Corvette
1962 Impala SS 409 dual quad, 4 speed
69 Blazer K5 - sold July '20
2019 Ram Rebel
rsavage is offline   Reply With Quote
Old 09-11-2019, 08:58 PM   #11
AussieinNC
Moderator
AussieinNC's Avatar
Sad to say...if you have metal on the dipstick you have already have damage...
Flat cammed engines NEED an oil with high levels of Zinc or a Zinc based additive like ZDDP....As your engine runs, it generates heat and friction, especially at high-stress points like the cams, valves, and tappets, where metal-to-metal contact pressures can be extreme. As this heat and friction builds, the ZDDP breaks down into its chemical components, coating the metal with what's called a tribofilm and taking the brunt of the load. This film forms at the atomic scale, helping to protect the metal in your engine, and reacts in a "smart" way, increasing the protection as the friction and pressure increases. By reducing direct metal-to-metal contact, the ZDDP provides a replenishable wear surface that prolongs the life of your engine. Studies of ZDDP have shown that it effectively provides a cushioning effect on the underlying metal, distributing the force upon it and, accordingly, the wear.
Amazon has it as an additive...or you can buy Oils with ZDDP in the mix...
Dont use ZDDP in oil that is destined for any engine with a Cat in the exhaust system...Zinc Kills Cats...thats why the oil companies dropped it out...
Family and country before all others...
2001 GMC Sierra
2006 Chevy Silverado (Daily Driver)
AussieinNC is offline   Reply With Quote
Old 09-11-2019, 09:49 PM   #12
Furno68C20
Good Info AussieinNC. What do I do from here? Keep running with zinc oil and hope it last, or suck it up and do a rebuild?
Old 09-12-2019, 08:43 AM   #13
bigmac73
bigmac73's Avatar
That is not good.... do u have some documentation to support ? I might have to swap to royal purple
Mike
Old 09-12-2019, 12:54 PM   #14
GASoline71
GASoline71's Avatar
If there is metal embedded in the bearings, it will eventually eat the journals of the crankshaft and cause catastrophic failure. I learned this the hard way about 10 years ago.
I don't have documentation per se', but if you do a Google search for Rotella, you'll see that all "diesel" oils have had their zinc and phsphorus either almost eliminated or greatly reduced from twhat they were 10 years ago.
Gary
Old 09-12-2019, 01:23 PM   #15
HO455
HO455's Avatar
Does the oil have a API designation? If so they have removed the majority of ZDDP. The standards changed so in order to maintain their rating they removed the zinc. Zinc kills catalytic convertors and now that diesel trucks have them the zinc had to go.
Here are some links if your interested.
https://www.speed-talk.com/forum/viewtopic.php?t=28365
https://www.bobistheoilguy.com
Old 09-12-2019, 04:28 PM   #16
AussieinNC
Moderator
AussieinNC's Avatar
I would run it so long as it holds up but in the interim maybe look to build a replacement...
If you decide to build a new one, suggest you source a VORTEC 350 roller engine core and start from there....
Depending on intended use, you could use the stock heads or maybe go with some aftermarket...depends on budget....
There are plenty of 350 Vortecs out there in wrecking yards...just watch out for cracked heads...
2001 GMC Sierra
Old 09-12-2019, 09:11 PM   #17
Furno68C20
Its funny you mentioned a 350 vortec build. I've got 010 350 block and a pair of Vortec heads at the machine shop getting worked on. Still going to use a flat tappet cam due to the block but I know now use the correct oil.
Old 09-13-2019, 01:21 AM   #18
Martyt
Guest
Posts: n/a
Lucas 15W-40 dino oil with ZDDplus for my K10, Jimmy and 69' FJ40
Old 09-13-2019, 06:56 PM   #19
AussieinNC
Moderator
AussieinNC's Avatar
I would not be building an 010 350 now unless its for a true restoration...go grab a 350 Vortec lower end and you get a roller motor that will run better and not cost you a fortune...
Just my ten cents worth
2001 GMC Sierra
1969, 292, 292ci, chevy
Copyright ©2000 - 2021, vBulletin Solutions Inc.
Copyright 1997-2020 67-72chevytrucks.com
