Old 07-01-2018, 11:45 PM   #1
suburban99
suburban99's Avatar
72 K10 Steering clunk left side leaf spring
Hey all... developed a steering clunk in the left side of my truck. It has a rebuilt lares steering gear recently installed. I don't think the clunk is coming from the steering gear. The left side spring lifts a little when you go lock to lock on the steering wheel...and makes a clunk. Spring bushings maybe?
1962 C10 Longbox LS 5.3 4L60E----Sold$$
2014 Ram 4x4 3500 Laramie Diesel..Momma's truck
2015 Ram 4x4 1500
1997 Boxster.
1972 K10 Custom Deluxe LS 6.0
1950 GMC 3100 S10 & LS swapped
suburban99 is offline   Reply With Quote
Old 07-02-2018, 06:29 AM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: 72 K10 Steering clunk left side leaf spring
I had a guy come over the other day that had a "clunk" in his steering...I crawled under while he turned the wheel....its was his steering box.....it was moving on the frame under load...the bolts even though tight were letting the box move....when it moved it would pop.....Mostly when he went to full lock...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 07-03-2018, 09:29 AM   #3
suburban99
suburban99's Avatar
Thanks Greg...that’s exactly what it was. Installed new lock washers and tightened...if it comes loose again I will loctite..Dan
2015 Ram 4x4 1500
1997 Boxster.
Old 07-03-2018, 01:23 PM   #4
mongocanfly
Post Whore
Glad you found it....do you have the reinforcing plate on your frame....these frames are notorious for cracking around the steering box....
Mongo...aka Greg
RIP Dad
RIP Jesse
