08-21-2018, 09:19 AM | #1 |
Rochester B rebuiding ?
Does anyone have a simple way of removing/getting the power piston out of a Rochester B carburetor?
I'm in the process of rebuilding mine but I am having a very hard time getting it to pull out.
Hollis |
08-21-2018, 11:22 AM | #2 |
Active Member
Re: Rochester B rebuiding ?
Here's one way: https://youtu.be/D3j1r27R2mA
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
08-21-2018, 12:33 PM | #3 | |
I finally got it a bit ago. Heated the whole top in a toaster over @ 200 for a few minutes and then was able to get it out. It was still tight though. Thanks for that video. Wish I had had it last night. Sure would have save a lot of @#$%^%$. This is my first carburetor rebuild, but knew it was suppose to come out of there.
Hollis |
08-21-2018, 11:57 PM | #4 |
Now I can't get the plunger to freely move without binding. I tried it in another carburetor and it moves find with no binding. Took that plunger that I had removed from the other carb and it binds in this horn/top also.
Are there anyway that anyone knows to repair that? I've cleaned it as best as I feel it can be cleaned. I can't see what it could be binding on either. ALSO… can anyone tell me what is suppose to be the stock carb for a 62 Chevy truck with a 235 motor?
Hollis |
08-22-2018, 11:06 PM | #5 | |
http://www.carburetor-blog.com/
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
08-23-2018, 08:12 AM | #6 | |
Hollis |
08-23-2018, 06:07 PM | #7 | |
Rochester B carbs were original to your application, but as you've discovered there are several different versions of the B carb. As for a replacement I highly recommend our N228 which is built to replace Rochester B carbs. It works on manual choke set ups only. There is an external adjustable main jet and a 360* adjustable throttle connector. http://www.carburetor-parts.com/Repl...-B_p_4411.html If I truly knew more about the motor or it's condition I might would just go that route. A rebuild is gonna cost me half that and it might be one of many things besides the carburetor causing the miss it has.
Hollis |
08-24-2018, 10:24 AM | #8 | |
Active Member
In YouTube search, type "rebuild a rochester b carburetor" or similar and you will get several hits.
08-24-2018, 01:26 PM | #9 | |
I haven't found the bore hole size posted anywhere yet. I miked the piston to be 11/32nd's.
Hollis |
08-24-2018, 04:44 PM | #10 |
Active Member
Yeah, I guess the binding piston can be a problem. The reason I mentioned doing your own work is that there are very few carburetor pros out there these days and the few that are there are not cheap. Years ago I bought a rebuilt one from a local auto shop and it was worse than the one I had. It's the reason I do my own work on the single barrel Rochesters. I bought some cheap ebay ones to use for parts. It may be the way you will need to go if the power piston hole is badly corroded.
