03-16-2015, 08:09 PM | #1 |
o2 senor question
If i delete my cats how could i stop the check engine lights
03-17-2015, 03:37 AM | #2 |
Parts and more parts
Re: o2 senor question
What year truck? Does it run on a computer chip or is it a tuneable computer setup?
Frank |
03-17-2015, 05:39 AM | #3 |
It's a 1993 TBI 350 engine
03-17-2015, 12:42 PM | #4 |
If it's stock it should only have 1 cat and 1 sensor. You might need to have a custom computer setup. If you are trying to improve gas mileage, you won't see any except a higher bill for the deleting.
03-17-2015, 01:47 PM | #5 |
You might have false oxygen sensor readings.
The cat will have a small amount of back pressure. That will keep some heat in the exhaust for proper oxygen sensor readings. If you remove the cat, it will let the exhaust escape faster, and the heat will not stay in the pipe long enough to keep the sensor at the correct temp. You can correct all of that by using a heated oxygen sensor. |
03-17-2015, 03:33 PM | #6 |
+1 on a heated o2 sensor.
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop |
03-17-2015, 03:44 PM | #7 |
have you had it scanned yet for the code? if I remember right you can take a paper clip to do this at home. But its been a while.
03-19-2015, 04:41 AM | #8 |
Rollin' Old Skool
On my old '93 C1500 with 350 TBI, I had the cat deleted. It never showed a check engine light. I know I personally didn't do anything to remove codes, & I don't recall the shop that did the cat-delete doing anything either. Made it a little louder, but it didn't hurt performance or gas mileage at all in my case.
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
03-19-2015, 03:31 PM | #9 |
There is none
After Cat O2 sensors did not come along till 1996 with the advent of OBDII.
So hack away. If anyone wants to know you get rear O2 simulators that connect in parallel to the O2 sensors to make the ECM think they are working. I used them for years until I had them programmed out. |
12-06-2017, 03:52 AM | #10 | |
Ans Every Place I Looked It Said >>>This part is not compatible with 1987 Chevrolet R10 Silverado Standard Cab Pickup 2-Door 5.7L 350Cu. In. V8 GAS OHV Naturally Aspirated. Do You Have A Part # For Me To Look At ?? Thank You Harley03joe
1931 Ford Like New And For Sale 2004 Harley Davidson Heritage Classic 1987 Chevy R 10 Silverado 2007 Azera 2011 Cadillac CTS Premium |
