Old 11-17-2017, 04:14 PM   #1
SCOTI
SCOTI's Avatar
Chevy to GMC Grille Swap
My 99 OBS has a worn/faded front end. Despite my love of Chevy's, I'm a "less is more" type & don't care for the Bowtie in the center bar. I'm planning to swap to a fresh GMC grille & was curious if other parts need to be swapped as well. Depending on what is correct on the NET, some say other items require swapping, while others say no.
Anyone that's done the swap on a 94-98, please advise.
Thanks!
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-17-2017, 07:48 PM   #2
95 S_Trucker
95 S_Trucker's Avatar
Re: Chevy to GMC Grille Swap
Head lights and turn signals are the same. The 4 corner lenses are different between Chevy and GMC.
The filler between the bumper is the same between makes. So is the core support.
All you need is the grill and the corner lenses.
95 S_Trucker is offline   Reply With Quote
Old 11-18-2017, 10:40 AM   #3
1badgmc
1badgmc's Avatar
Yep. As long as you're sticking with a '94-'98 GMC grille, all you'll need are the grille and corner lenses. Everything else is the same.
Old 11-18-2017, 08:19 PM   #4
SCOTI
SCOTI's Avatar
Excellent! My plan was to replace all the lighting lenses so I figured thats the perfect opportunity to update to a fresh grille w/o a badge. They will compliment the new impact-strip free bumpers already swapped on.
Thanks guys.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-04-2017, 12:21 PM   #5
likaroc13
Rollin' Old Skool
Yep, what those guys said! I don't mind the Chevy grille but prefer the GMC version as well. What are you planning for the light replacements?
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 12-04-2017, 03:42 PM   #6
SCOTI
SCOTI's Avatar
Just direct replacements. I'm not a fan of the LED trend lighting (I like the factory appearance).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-05-2017, 03:44 AM   #7
likaroc13
Rollin' Old Skool
Same here, at least when it comes to exterior lighting lenses. If you don't mind, report back with where you purchase the new lights & your thoughts on them.
Phillip
My Build threads:
Pics:
Previous Rides:
Old 12-05-2017, 08:23 AM   #8
TexasJeff
Don't Crush em Restore em
TexasJeff's Avatar
I have a '98 and was thinking I would like to do the same thing at some point, Scoti please take pictures of the finished product.
TexasJeff
2009 Silver with Linen Interior Cadillac DTS
1990 Red with White Top and Interior Ford Mustang GT convertible
1998 Red with Gray Interior, C3500 Chevy Crew Cab Dually
TexasJeff is offline   Reply With Quote
Old 12-05-2017, 08:54 AM   #9
likaroc13
Rollin' Old Skool
If you'd like to look, I have some before/after pics of my old truck that I did the grille swap on.
Phillip
My Build threads:
Pics:
Previous Rides:
Old 12-05-2017, 10:32 AM   #10
SCOTI
SCOTI's Avatar
I've used TYC Genera lenses in the past. Their tail lights fit like OE vs the other common supplier from LMC.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-06-2017, 12:01 AM   #11
TennesseeZ
Countdown Survivor
TennesseeZ's Avatar
I like the GMC grille better also. I've changed a few, the info above is correct, nothing to it with the right stuff.
93 Yukon
89 Silverado Z71 SWB Sport
91 K 2500 Silverado "Lobuk-Worktruk"
A MAN OF HONOR DOES NOT LIE, CHEAT, OR STEAL, NOR TOLERATE THOSE WHO DO.
Gettin' old ain't for sissies.
TennesseeZ is offline   Reply With Quote
Old 12-06-2017, 03:45 AM   #12
likaroc13
Rollin' Old Skool
I bought a pair of TYC tails on Amazon. I don't recall them being Genera though. I had them custom painted but ended up with one not coming out exactly as I want. So, they're about to get redone. What mfg are you looking at for the headlights/parking lamps?
Phillip
My Build threads:
Pics:
Previous Rides:
Old 12-06-2017, 09:22 AM   #13
SCOTI
SCOTI's Avatar
Based on the fit quality vs the other brand from LMC (Depot?), I'm looking @ the TYC front lighting group as well. Let's just say I had to do multiple set's of the LMC rears because of poor alignment quality. When you would go to tighten them down, they would be in a bind & chipped the corners on a lens (2 different sets). Despite understanding the problem, it still repeated itself.
I tried the TYC's on the 99 as my local Oreillys had a pair on the shelf. They went in as easy as the factory pieces came out. Zero issues.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-06-2017, 12:41 PM   #14
likaroc13
Rollin' Old Skool
I saw those TYC tails in my local Oreilly store as well. I assume those are equivalent to what I purchased on Amazon. I test fitted one of mine after purchasing, & it seemed to fit good. One very minor thing I recall was that the edges of the plastic had some areas that weren't cut very smoothly. I carefully used my Dremel to make them a little better.
Phillip
My Build threads:
Pics:
Previous Rides:
Old 12-12-2017, 05:48 PM   #15
slime
slime's Avatar
Good info here. I would like to do the same with my 96 truck, so that's nice to know.
slime is offline   Reply With Quote
Old 12-12-2017, 07:02 PM   #16
mountie
mountie's Avatar
I replaced my rear lenses with the TLC brand .... BE CAREFUL....
The upper corners of the lens are very brittle & a bit thinner than factory.
The first lens I installed broke at the upper corner as it just pressed against the soft rubber weather strip. ( O' Reilly parts swapped it)
I was more careful next time.
'70 GTO Midnight Blue
'88 GMC Sierra SLE 392,000 miles-(2018) sold to Classic car shop in Germany.
'93 Cadillac STS Black
'93 Mercedes SL 500 Teal
'86 Yamaha FZ750 - 15,000 RPM
'86 Yamaha FJ1200 - Criminally Fast
2016 Ferrari 488 GTB, I drive it - don't own it.
'05 GMC Yukon XL , SLT 4wd ( just purchased 2018)
mountie is offline   Reply With Quote
Old 12-12-2017, 07:57 PM   #17
SCOTI
SCOTI's Avatar
Weird. That's the exact problem I had w/the tail lights I purchased from LMC. On both sets, one of them chipped the corner off as they were be tightened up.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
