03-16-2019, 03:35 AM | #1 |
70 C20 4x4 front brake drums
HI,
I'm looking for some brake drums for my 70 4x4. They are 8 lug drums and I can't find them anywhere. I was told if I found a 71 and got everything from the knuckles out, I could convert front end to disc brakes. Any suggestions or recommendations would be greatly appreciated. Jeff |
03-16-2019, 01:08 PM | #2 |
Re: 70 C20 4x4 front brake drums
I don't believe front drums are available. I converted my '70 K20 to disc but I used a complete donor axle from a '71. I believe you just need the parts from the knuckle out but am not sure.
It may be just as cheap to buy a complete disc D44. GM put them under square bodies until the mid '70's. The bonus with the later 44's is you get the larger axle u-joints. |
03-16-2019, 02:12 PM | #3 | |
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F2 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
03-16-2019, 03:35 PM | #4 |
1971 to 1976 will work
03-16-2019, 09:56 PM | #5 | |
Thank you all for your suggestions and help. |
03-16-2019, 11:27 PM | #6 |
I used the axle from a 71 gmc K25. I have the whole truck, I've just about stripped all of the good parts off of it. (bought 2 worn out trucks to make one worn out truck!)
What I meant by a complete disc D44 is just the whole axle. I've seen them for sale pretty cheap ($100) but it depends on condition, etc. |
03-17-2019, 09:45 AM | #7 | |
https://en.m.wikipedia.org/wiki/Dana_44 You would be looking for an open knuckle disc brake version. From a 1971 to 1975 Chevy/ GMC truck, Blazer or Suburban.
03-20-2019, 10:37 PM | #8 | |
03-23-2019, 08:27 AM | #9 |
I Just converted my 68 c20 to front disc. I have the old drums and knuckles 8 lug.
03-23-2019, 11:23 AM | #10 |
Proprietor of Dale's Corner
I have a 72 Dana 44 HD that I'm getting ready to put ont the parts board.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
03-23-2019, 09:39 PM | #11 | |
Posted via Mobile Device |
03-24-2019, 11:35 AM | #12 |
'70 was a "one year only" open knuckle, drum brake. Guess the drums are different from '69 back? Just looked on Rock Auto, no front drums listed for a 70. Front drums listed for a 69 but out of stock.
03-24-2019, 04:12 PM | #13 |
Before this conclusion becomes Internet Truth, does anyone have '69 drums and '70 drums to compare? Rock Auto's listings are not infallible.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
03-24-2019, 07:17 PM | #14 |
That would be good to know. The 69 & 70's do share the same brake shoes & wheel cylinders (CQ shows 69 has a standard & HD wheel cylinder, 70 only lists a HD)
I would think the only difference in the drums (if there is a difference) would be the center bore. Or, maybe the mounting surface is a different height? |
