01-25-2019, 03:17 PM | #1 |
sm465 linkage help
1972 Blazer 454 with sm465 and headers.....what are you doing for clutch linkage?
1972 Cheyenne Super..owned since 1978 1972 Surburban 4x4 1972 Cheyenne 4x4 3/4 ton.....sold 1972 Cheyenne 2wd...named Death Row |
01-25-2019, 03:21 PM | #2 |
Post Whore
Re: sm465 linkage help
Are you talking about everything?....or just a specific part.....
01-25-2019, 05:16 PM | #3 |
all of it....factory z bar will not clear headers...has anyone gone to a hydraulic setup?
01-26-2019, 12:13 AM | #4 |
60-66 Nut
Converting to a hydraulic clutch is certainly a easy way to solve the issue with a big block conversion.
http://www.67-72chevytrucks.com/vboa...d.php?t=652871
01-26-2019, 12:32 AM | #5 |
Post Whore
yeah I agree...hyd is the easiest way
01-26-2019, 01:54 AM | #6 |
01-26-2019, 10:08 AM | #7 |
Best forum period.
01-28-2019, 09:44 PM | #8 |
There is no pulling the engine forward because the 4x4 uses a different crossmember.
Either get rid of the headers and get a set of Heddmans which will clear the factory linkage or get a set of 2 1/2" manifolds. I had some Doug Thorley chrome tr-y's I want to run years ago but had some issue. Bought a cheap set of headers and they didn't work. Ran the Heddmans and OEM linkage for 12 years or so. Then I went to the 'vette manifolds and that is what I would recommend anyone else do as well.
01-29-2019, 01:38 AM | #9 |
Um, yes you can pull the engine forward. Unbolt it and move it forward, redrill. And yes there may be a clearance issue with the oil pan on the 454 that may need to be addressed. Just moved an engine forward on a customers 72 to put a T400 in and a doubler. My customer retained the 350, so I just used a 2wd fan shroud. Just recently helped my son-in-law install a 454 in his 68 3/4 ton. We converted to 4x and 454. Used the 2wd bolt holes and I had a set of big block stands. He bent a piece of 3/8'' flat plate steel to connect the lower part of the stands as a x-member
01-30-2019, 09:20 AM | #10 |
I can’t believe I read that first thread and didn’t see it was a 454.
I know you can do all of that to move the motor forward, but usually a question such as that precludes the poster from such work because they asked a simple question. Obviously my mistake as the big block swap doesn’t allow for an easy bolt in swap. Mea culpa.
02-26-2019, 09:36 PM | #11 |
Without photos, I don't know on your big block, but when I put a small block in my truck, I cut off the bottom lever of the z-bar and welded it back a couple of inches over to clear the headers. But careful not to go to far or it will pop off when you press it in.
Just an idea.
1967 C-10 4-speed, 350v8 |
03-02-2019, 01:36 AM | #12 |
CharlieBrown,
I have a SBC 400 CI with a SM420, I did what Dave12 also had done, I put on set of long tube headers and had to move the lower clutch rod over to the end of the Z Bar, I also shortened and threaded the lower rod and used a rod end for the connection... it works real nice! Joe |
03-02-2019, 01:40 AM | #13 |
One more pic....
03-02-2019, 02:55 AM | #14 |
Post Whore
that looks awful close right there ...is that a before or after?
03-09-2019, 07:05 AM | #15 |
Six in a row makes it go...
These guys might know about hydraulic options since they do a lot of SM465 swaps.
https://www.novak-adapt.com
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
