Old 03-06-2019, 11:02 PM   #1
wpavlis
Engine install tip
I should be getting my engine back from the machine shop soon. I have a couple friends willing to help but i thought i would ask if anyone has any general tips or tricks to share?
I was also wondering about the best way to reinstall the transmission. Its a 3 speed column shifted unit. Would it be easiest to install it and the clutch prior to installing the motor or should i just install it after installing the motor. I have a transmission jack if thats the easier way to go.
Thanks for any advice you can give.
1968 c10 lwb
wpavlis is offline   Reply With Quote
Old 03-06-2019, 11:13 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Engine install tip
At the very least I would have the clutch a p-plate installed before I put the engine in.
Use a clutch alignment tool to do this...
ive done it both ways..all together and in pieces....really depends on the equipment you have...
Engine hoist,,,,leveler,,,,,trans jack,,,,,buddies..
..but its easier to put it all together in the floor.....and then install as one unit
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 03-06-2019, 11:37 PM   #3
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Bolt it all together and install it as one unit. I use a lift plate bolted to the intake to lift engine/tranmission combos all the time.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 03-06-2019, 11:52 PM   #4
wpavlis
Thanks. I don't have an engine leveler but i do have one of those carb plate lifters. At a minimum i figured the clutch assembly should be installed. Can you put the clutch fork in after the transmission? I figured it would get in the way if it was installed.
Old 03-07-2019, 12:54 AM   #5
mongocanfly
Post Whore
Mines a different setup...but I put mine all together with out the clutch fork in...planned on doing it after the install...would not go...had to tear it all back apart....lesson learned...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 03-12-2019, 05:01 PM   #6
mattfranklin
mattfranklin's Avatar
With a smaller transmission it's easier. With my monster SM465 I have to do the transmission separate from the engine. Just couldn't manage to clear everything, even with the shifter removed. If the cab were off, I would have been ok, though.
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1
http://67-72chevytrucks.com/vboard/s...d.php?t=567340
mattfranklin is offline   Reply With Quote
Old 03-12-2019, 05:35 PM   #7
wpavlis
I should be getting the motor back this weekend. My plan currently is to install the intake, pan and timing cover this weekend. Then next weekend install the bellhousing, flywheel and clutch and drop the motor in. I will then install the clutch fork and transmission.
I took my motor stands off and sandblast and painted them. I noticed they are somewhat adjustable. What do i need to do in order to make sure the motor is aligned correctly? I am probably overthinking this.
Old 03-12-2019, 08:54 PM   #8
Dead Parrot
Install and shim the starter while the engine is out. Practice stabbing the transmission and installing the fork with the engine out. That way you already know any issues before you are underneath the truck looking up and cussing at something that isn't going together.
Depending on how much of the front end is out of the way, install the balancer, main pulley and water pump.
Put an old set of plugs in to prevent any crap from getting in the cylinders during installation. Clean rags in the exhaust ports for same reason.
Dead Parrot is offline   Reply With Quote
Old 03-13-2019, 12:27 AM   #9
mongocanfly
Post Whore
better make sure you can install the clutch fork after assembly before you assemble...I found out the hard way mine wouldn't go in after assembly..had to pull it all back apart
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 03-13-2019, 06:48 AM   #10
rsavage
rsavage's Avatar
NO. The transmission input shaft would more than likely be in the way even if you had the clutch release bearing on the input shaft already ( can't put it on after the transmission is in). The bearing (make sure you put it on the right way) should be snapped into the fork and the fork on the ball of the bell housing prior to the trans being installed. Make sure your motor has a good pilot bushing in the end of the crank.
Do the job on a concrete smooth and level area.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Thread Tools
Display Modes
