Old 05-17-2002, 04:11 PM   #1
Krawler
Post Rear brake failure
Hello every this is my first post.
I have a 72 c10 with front disc brakes and a 70 3/4 drum rear, my rear passenger side brake was locking up so I replaced the wheel cylinder, it was in bad shape, and went to bleed the brakes in the back. after bleeding the air outta the new wheel cylinder I found the master cylinder was empty and filled it back up, now I have no pressure to the back brakes but plenty to the front. I also have a trailer brake setup on my truck mounted under the steering wheel and it wasnt getting pressure there either. Is it my proportioning vavle, or can 1/2 the master cylinder go bad?
Krawler is offline   Reply With Quote
Old 05-18-2002, 09:46 PM   #2
1971LT1SWBPOSI373
1971LT1SWBPOSI373's Avatar
Post
You should be ok, but it sounds like you need to bleed the master cylinder. You can buy a cheap bleeder kit for about 5 dollars, and the procedure is published in Chiltons or Clymer manuals. It's a real pain, but with time and effort, can be corrected. I think whats happening is the master cylinder is vapor locking, due to lack of fluid. Good luck.
1971 Shortbed 350/350 w/ Posi-traction 3:73's
1996 Chevy Silverado
TJ in Springfield, Virginia
Likes old Chevy trucks
Drinks Miller MGD
1971LT1SWBPOSI373 is offline   Reply With Quote
