Old 04-23-2003, 10:15 PM   #26
Jackal2k9
Jackal2k9's Avatar
thanks pickmup. I havnt nstalled photoshop on this pc yet... it's kinda slow so i dont want to. heheh ty agian.
Jackal2k9 is offline   Reply With Quote
Old 04-23-2003, 11:39 PM   #27
oldsub86
Have a look at this site.
http://www.classictruckshop.com/club...oling/fans.htm
1968 Chevy - 292 with a powerglide
oldsub86 is offline   Reply With Quote
Old 04-23-2003, 11:47 PM   #28
Jackal2k9
Jackal2k9's Avatar
i like the wireing setup on that one a lot. well thought out. These fans draw so few amps though that i can just leave them running all the time. It hasnt overheated so far. It's been through some HOT summers too. But there would be a power increase if they were only on then the temp was up. I think im gonna get me a temp switch.
Old 04-24-2003, 01:31 AM   #29
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
I put the fan and radiator in my 4x4 from a 91 Lumina APV. I haven't got a relay for it yet, just a 10A toggle switch and keep an eye on the temp gauge.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 04-24-2003, 08:08 AM   #30
Jwill41
Jwill41's Avatar
I read the other day that the temp sensor should be in radiator instead of the block. The fan should come on when the hot water is sent to the radiator. The thermostat lets the cooled water from the radiator back into the block. Kinda makes sense to me.
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline   Reply With Quote
Old 04-24-2003, 10:56 AM   #31
6869704X4
re: the link above.
Seems like I bought a thermostat at Advance for about what he paid for a water heater stat. Comes with everything, including directions. I'm using a GM relay that I cut out of a olds, I think it might have been the AC relay. Nice weatherproof plug on it(these work great for the headlights too).
The more I learn about women, the more I love my truck.
6869704X4 is offline   Reply With Quote
Old 04-24-2003, 12:23 PM   #32
MITCH1914
MITCH1914's Avatar
thanks for the feedback. gonna vist some junk yards.
MITCH1914 is offline   Reply With Quote
Old 04-28-2003, 04:41 PM   #33
dubie
dubie's Avatar
this is a great upgrade topic that I thought should be brought back up to the top
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 04-29-2003, 06:54 PM   #34
Jwill41
Jwill41's Avatar
cheaper than "Painless"
I found this today at Pep Boys. It has everything you need. Fuse, relay, temp probe, hardware and wire harness for 30 bucks. That is much cheaper than "Painless" and has the radiator temp probe instead of the block sending unit.
Old 04-29-2003, 07:08 PM   #35
Low69CST
I think the fans need to come on when the heads on the motor get to a certain temp. Common knowledge that engine (head area) needs to be about 200 to make good power and under 240 to keep from doing damage, so the fans should come on when the engine itself gets above that tempature and give extra cooling to the water which inturns cools the motor. my truck cycles perfect, fans kick on when the motor gets up to 205 and cuts off when it cools back down to 185 (think)
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 04-29-2003, 07:30 PM   #36
Jwill41
Jwill41's Avatar
This is going to start something I think. LOL.
The fans do not cool the block. They cool the water that has left the block because it got too hot and the thermostat returned it to the radiator. I agree the head temp should be as you say but the thermostat in the block takes care of that. The type in the pic also comes in an adjustable model.
Old 05-02-2003, 02:57 AM   #37
ZOOMY
ttt
Any more ideas ?????............Zoomy
ZOOMY is offline   Reply With Quote
Old 05-02-2003, 01:45 PM   #38
biglou55
Jackal2k9 I would like the wiring diagram and parts list too. If you would be so kind THANK,S biglou email -hale@gcc.mass.edu
Certifiably crazy person
biglou55 is offline   Reply With Quote
Old 05-02-2003, 02:16 PM   #39
dubie
dubie's Avatar
wiring diagram is posted here
http://67-72chevytrucks.com/vboard/s...threadid=50085
