Old 08-07-2017, 03:35 PM   #51
68Gold/white
Re: 1972 C10 ... SoCal BBC/TH400
Good work on the engine stand!!!
Some time, if possible. I'd like to see some pictures of where there the drip rail was removed. Front and side, for reference...Thanks!!!
68Gold/white is offline   Reply With Quote
Old 08-08-2017, 12:04 PM   #52
bs46488
Its officially...8 mile maiden voyage. No major issues, but a couple things to address.
First stop....the gas station.
Project Engine Stand 1972 SWB conversion: http://67-72chevytrucks.com/vboard/s...d.php?t=673914
1970 Nova: http://67-72chevytrucks.com/vboard/s...d.php?t=708161
bs46488 is offline   Reply With Quote
Old 08-08-2017, 12:14 PM   #53
bs46488
68Gold/White...not sure if this drip rail removal is the best example. It looks like the previous owner removed the rail with a dull axle, then randomly welded the aftermath with a stick welder in the dark.
I added some more mig welds and some time with the grinder wheel. Then there is a "fair" amount of body filler in there to make it look presentable.
Old 08-08-2017, 07:33 PM   #54
rustytruck50
rustytruck50's Avatar
That turned out great!
-Doug
'05 RCSB Sierra 2WD
'71 Sierra 2WD Longbed
'98 Silverado K1500 Xcab...sold
'72 Highlander"Raymond"...sold
rustytruck50 is offline   Reply With Quote
Old 08-11-2017, 02:17 PM   #55
RedRider
RedRider's Avatar
This is a sweet truck! I love everything about this build, especially all the DIY you put into it.
RedRider is offline   Reply With Quote
Old 08-18-2017, 12:58 PM   #56
stevenfromtexas
stevenfromtexas's Avatar
pickup looks good brother. we spoke a few weeks ago about the metallic issues you had. do you have any other advice on technique/distance form the panel/top to bottom spraying.....stuff like that.
thank you
Steven
'67 SWB, 250ci, 3OTT.......this is my first build......
I wonder if my grand kids will say, "I would give anything to have my grand dads 2005 Chevrolet Z71"
stevenfromtexas is offline   Reply With Quote
Old 08-28-2017, 02:08 PM   #57
beaterku
beaterku's Avatar
Got the cab painted
Today I put the bed (and wheels) on it. Feels like I was actually getting the truck back together vs still taking it apart. Now I'm hoping to start adding more and more parts to the project.
Going to switch gears and start doing some wood working on my bed floor.
What wheels are these?
beaterku is offline   Reply With Quote
Old 08-28-2017, 02:13 PM   #58
Willie G
Looking real good B.
Willie G is offline   Reply With Quote
Old 08-28-2017, 02:22 PM   #59
bs46488
I have the US Mags - Rambler wheels. I bought this set used off another board member. I recently painted them gold.
Regarding the paint - I would certainly paint another vehicle, but I'm not sure metallic will be used. I think you just need more practice to spray a good metallic paint. Most likely my other project will get a solid color paint job.
As I expected, the bugs are starting to surface with some miles. It didn't run well. Checked the timing (it was at 4 degrees) and replaced the plugs to find 7 fouled plugs and 1 plug that was cracked in half. Its running better now.
The steering on the truck is horrible, so I've been working on that this week.
And still have a persistent drip from the trans.
But its a lot of fun to drive!!!
Old 08-28-2017, 02:23 PM   #60
beaterku
beaterku's Avatar
Thanks!
Old 08-28-2017, 02:28 PM   #61
Willie G
Keep up the good work B. mine should be drivable before Christmas , if all goes well. lol
Old 09-13-2017, 12:37 PM   #62
bs46488
Well that was short lived....
Ended up having an electrical gremlin and the truck would just shutting down. Decided it was the old MSD stuff that the previous owner had. I put in a HEI and haven't had an issue since.
Update on the steering: Ended up replacing the steering box. Was fighting a couple of
stubborn leaks and had a bind with the rag joint, but now it everything is smooth and responsive. Much nicer than the old worn out box.
So this past Sunday I got the truck out for a cruise to test out the steering. Was just cruising down the street and got a nasty sounding misfire. I just turned around and went home. Monday night I pulled the valve cover off to find the rocker stud on cylinder #5 was snapped in half.
Last night I pulled a good stud to get some measurements to order new rocker studs and found the valve spring on cylinder #1 is cracked and the spring is basically riding on itself.
So now the heads need to come off and I need to figure out how to rebuild them or what to replace them with.
Total miles driven on project....48
Old 04-02-2018, 12:53 PM   #63
bs46488
Finishing up the bed of my truck....
Old 04-02-2018, 01:08 PM   #64
Willie G
That's Awesome B. I finally got back to the truck, been out of it almost a year. Really hitting it hard this time around. No set dates, just lots of working on the truck. We will see how that goes. I'm glad you are posting updates, its inspiring me to keep on trukkin. LOL. Wil
Old 04-12-2018, 04:20 PM   #65
bs46488
So many bolts, washers, lock washers, and nuts on the bed!
But starting to look a little different....
Old 06-26-2018, 01:40 PM   #66
bs46488
I think this is considered a change order....LS swap in the very near future!
Old 06-26-2018, 04:05 PM   #67
RedRider
RedRider's Avatar
Yes! I'm in the process of an LS swap myself, but my engine wasn't has pretty as yours.
1970 C-10 "Old Yeller"
Old 06-26-2018, 04:10 PM   #68
Willie G
Also in the process of LS Swap. lol.
Old 07-06-2018, 06:32 PM   #69
bs46488
Found a used 5.3/4l60e from a 2005 Silverado.
Now comes the fun part
Old 07-06-2018, 07:14 PM   #70
Willie G
sweet. Looking good. Is it ready to pop in or are you going to work it? Cam, springs?
Old 07-06-2018, 10:31 PM   #71
RedRider
RedRider's Avatar
Yeaa buddy! Time to change the thread title
Old 07-07-2018, 06:10 PM   #72
builtbyKane
builtbyKane's Avatar
Score that looks like a clean motor. Hope the install goes smooth for you.
builtbyKane is offline   Reply With Quote
Old 07-13-2018, 03:07 PM   #73
bs46488
Been working on doing the DIY stand alone wire harness (and a little custom wire tuck) while waiting for parts to arrive.
And parts are arriving. Its like christmas in July in the bed of my truck
Old 07-14-2018, 01:27 AM   #74
Willie G
Nice goodies. Gonna be sweet. what oil pan is that. What you gonna do to the 5.3?
Old 07-31-2018, 06:48 PM   #75
bs46488
I'm not planning any engine mods to the 5.3 (yet). I'd like to get the engine in the truck and get a few hundred miles in it before I make changes.
The oil pan is a factory replacement F-Body Camaro purchased dirt cheap from Rockauto.com
The wire harness modifications are done. Just need to complete the fuse box and relays. Then I'll wrap it in split loom
Got a bracket mocked up to mount my DBW pedal. Need to finish weld and paint
Modified the sender on my LMC bed mounted gas tank for the return line
