10-13-2018, 05:02 PM | #1 |
turbo 4.3
can you run a blow through turbo thru a 93 tbi, necessary mods? recommended turbo size. looking for around 100hp gain , maybea little less
thanks, dave |
10-13-2018, 06:58 PM | #2 |
Moderator
Re: turbo 4.3
Put a 350 in it!
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
10-13-2018, 09:14 PM | #3 |
Re: turbo 4.3
I believe your referring to modification of the TBI housing. It should not be an issue but the stock TBI is limited in CFM. May try a 454 housing with the correct injectors meating your fuel requirements or maybe move to an aftermarket injection system with more flow.
I would go aftermarket due to the availability to monitor and modify the programming. TBI can be modified, but that’s a completely different learning curve. Lots of info on http://www.tbichips.com What mods are currently done? I see most the time you can get more horsepower out of a properly built engine then you can a turbo, this due to turbos being installed on stock platforms. If your looking for power I always recommend a good engine, turbos are best used on built engines. Last edited by mikebte; 10-14-2018 at 09:44 AM. Reason: Spellin |
10-17-2018, 07:16 PM | #4 |
driving is in my blood
Re: turbo 4.3
You wanna spend thousands on an old v6 power truck to gain 100hp?
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
