Old 09-20-2018, 05:38 PM   #1
Bnapier0730
Question Wheels
I have a 72 c10 that I want to make look like a shop truck I want the 20 inch ridler wheels I found some that are 10 inch wide in the rear and 8.5 in the front I want to lower it no more than 6 inches just a good looking stance and drivable will those work and does it matter that they are offset like that to go 6 inches and what's the major differences in them I know there 8 inches and 10 inches so does that mean the back will stick out 10 inches wider than the front? And will they still clear everything thanks
Bnapier0730 is offline   Reply With Quote
Old 09-20-2018, 09:55 PM   #2
88gtstreetrod
Re: Wheels
You want 5.5 backspacing on the 20x10. And you want 4.5 backspacing on the 201x8.5. you should clear fine.
I ran these on my truck with a 5.5 drop in the front and 5 in the rear. Hear is a pic with the set up including a 1 inch spacer in the back
88gtstreetrod is offline   Reply With Quote
