09-09-2011, 10:33 PM | #1 |
how to decode my engine
chevy engine code 11d140881 t1229cjd
09-09-2011, 10:58 PM | #2 |
"Where were you in '62?"
Re: how to decode my engine
The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Engine & Drivetrain
Online engine resources (casting numbers, calculators, etc.) http://67-72chevytrucks.com/vboard/s...d.php?t=382583 Small Block Chevy Engine Block Identification http://67-72chevytrucks.com/vboard/s...d.php?t=353538 Big Block Chevy Engine Block Identification http://67-72chevytrucks.com/vboard/s...d.php?t=357304 Engine I.D. and Codes - YearOne.com http://www.yearone.com/updatedsingle...ngineinfo1.asp http://www.yearone.com/updatedsingle...ngineinfo2.asp http://www.yearone.com/updatedsingle...ngineinfo3.asp http://www.yearone.com/updatedsingle...ngineinfo4.asp http://www.yearone.com/updatedsingle...ngineinfo5.asp http://www.yearone.com/updatedsingle...ngineinfo6.asp By far the fastest and easiest way to I.D. your small block Chevy is to use the casting number found on the driver’s side rear of the block on the top flange that mates with the tranny bell housing. Numbers are raised approx 1/8 of an inch. The are about 3/4 of an inch tall. Even though you may have to scrap grease and dirt away, the numbers may be seen plainly while the engine is still in the car. The casting date can also be very helpful in identification. Found normally on the top or the right side of the same flange that mates to the transmission bell housing. (Behind & below the distributor).They can also be located on the right side of the block next to a freeze plug. You will either find an alpha-numeric date code cast right into the block between the images of two screws cast into the block; these are from the screws that held the date code plate while the block was being cast. This code I.D.s the month, day, and the year of the casting; note that this does not mean that the casting date was also the model year of the vehicle that rolled out of the factory with said engine. While there were a pile of minor changes in the last 40 years to the small block Chevy, the basic design has remained the same for the years we are looking at on this site. The very first small block Chevy, a 265 CID overhead valve v-8, did not even have a provision for an oil filter! The familiar oil filter boss on the small block came around in 56, along with an all new casting. The debut of the 283 in 1957 marked the end of the 265.Chevrolet went to a new motor mounting system placing the mounts near the freeze plugs on the side of the block. The old system had mounts located on the front of the block at either side of the timing cover. Since around 1964 most small block Chevys have had two threaded holes at the rear of the block on the driver’s side near the oil filter boss. These are to accommodate the clutch counter shaft for vehicles equip with manual transmissions. Only one of the holes is required. Some vehicles used a counter shaft located approx 6" further to the rear, thus the need for the rear hole. Early blocks have only one hole and are pretty much worthless to a vehicle that requires the rear hole for their clutch assemblies. Before 63, small block Chevy engine used a "Road Draft Tube" to ventilate the crankcase. Featuring a large hole at the top rear of the block inside the lifter valley, these blocks are from the 50's through to the mid 60's.The PCV (positive crankcase ventilation system) replaced the daft tube in 1963.The vent hole disappeared in 68 when the system was redesigned to ventilate through the oil filler tube located at the front of the intake manifold. Later engine ventilated through the valve cover. In 62 Chevy brought out the Chevy II, or Chevy Deuce. Using an inverted front suspension, the Chevy II had shock towers in the engine bay, which put the steering arms right where an oil pan would go. This little problem was solved for the small block applications (4 and 6 cylinder applications had no problem with this configuration) with a special block with a recessed oil filter boss, and an oil dipstick located on the passenger side. The problem was done away with in 68 with a new chassis and body style. The unique 64-67 blocks are in demand by collectors due to the recessed oil filter boss. With the debut of the 327 in 62, Chevrolet fans were in heaven. Fitted with its own unique valve cover the featured a flat spot for a decal like "327 Turbo Fire”. This design was used until around 1965 and is very popular with collector’s today.1956-1967; small block Chevys also used a cartridge type oil filter inside a steel canister, joining other manufacturers in 68 with a spin on style oil filter. There are adapters available to update the older style blocks to the newer style. Several other changes took place to the small block Chevy in 67.It was the lst year of the 283 and the first year of the 350(Camaro only).It was also the first of three years for the very famous 302 Chevy(283 crank in a 327 block) 1968 was the year that Chevy started making the small blocks with large journal cranks, greatly improving strength and durability to the crank. This also means that small journal (pre 68) cranks do not fit large journal block (post 68) although this change did not occur until around March or April of 68. (This writer had a Mar 68 327 that was a small journal and has a may 68 327 that is a large journal.) 1968 marked the first year of the 307.The 307 utilized the stroke of a 327 and the bore of a 283.Chevy tried again with an economy small block with the 305, most are now boat anchors to the best of this writer’s knowledge. 1969 brought with it 4 bolt main bearing caps further strengthening the bottom end of the small block for high performance and heavy duty applications.69 also marked the last year on the 327 as well as the 302. Growing to its largest factory displacement of 400 cubic inches in 1970, these block required Siamese cylinders to gain the internal space for the displacement. Extra bolt holes were also drilled into the surface of each deck to promote cooling. It is also noted that for the use of a small block 400, you also need the small block 400 heads. Most of the crankshafts and connecting rods from the small block 400's ended up with a better life as part of a 383 build-up. Another year of change was 1986.The two piece rear main seal was replaced with a one piece unit. Displacement of the block was also cast into the block next to the casting number. Small Block Chevy V8 Casting Numbers http://www.mortec.com/castnum.htm
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. Last edited by 1Bad62Pro/Street; 04-16-2014 at 09:55 PM. |
09-27-2011, 03:34 AM | #3 |
My casting numbers do not have the 3 in front of it all that is there is 61959 and there is no grind marks were the 3 should have been and im asumeing there would have been a 3 cuz the other numbers are on your list . can you tell me if this correct or do I have some half breed thanks
09-27-2011, 06:39 AM | #4 | |
Original engine in truck?
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
09-27-2011, 06:50 AM | #5 |
CJD suffix codes were all `71 350 from what I`ve experienced, assuming its a V8....
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
09-27-2011, 06:30 PM | #6 |
is a fungineer
11D140881 Chevy 71 Doraville
T1229CJD Tonawonda Dec 29 '71 350 270HP 4bbl Hyd cam T350 trans L-48 engine code
2003 S10, 2.2 auto- the daily driver, currently with a 2"/2" drop and some minor engine bolt-ons 1978 Impala 2-door, race 350/T350 - the new race car, in progress 1968 Chevy C10 longbed- 3/5 drop, currently undergoing a heart transplant |
09-28-2011, 11:01 AM | #7 |
04-14-2014, 08:58 PM | #8 |
Can anyone help decode my engine...these are the numbers ive found;
By the Alternator 16D492959 T0401CPB By the Distributor 14014431 At the rear of engine close to the transmission im seeing GM355909 |
04-14-2014, 09:57 PM | #9 |
is a fungineer
CPB 76 305 Nova 140 LG-3 TH 350 2-Brl
CPB 76 305 Chevelle 140 LG-3 TH 350 2-Brl CPB 76 305 Camaro 140 LG-3 TH 350 2-Brl CPB 80 267 Chevelle 120 L-39 TH 350 2-Brl 355909 is 76-79 262/305. The 14014431 is the intake casting number. So you most likely have a 1976 305.
04-14-2014, 10:14 PM | #10 | |
Much Thanks! |
11-06-2014, 08:07 AM | #11 |
I have just purchased a 1972 Blazer and I know it does not have the original engine so I'm trying to find out what engine it does have. So far:
Suffix Code: V0914TKB tells me it a 1976 350 engine (I think) Block Casting: 3970010 tells me it a 350 from 69-88 Partial VIN: C7Z121682 This is the part that I can't find any information on. Does anyone have any info for this partial VIN? All the sites I have been on expects the '13' in front for a 'Chevy" "1973" Any help would be greatly appreciated.
11-06-2014, 03:40 PM | #12 |
is a fungineer
TKB 76 350 Truck 165 LS-9 4-Brl
TKB 77 350 Truck 165 LS-9 4-Brl TKB 79 350 Truck 165 LS-9 4-Brl TKB 92 350 Truck 210 L-05 TBI So you ruled the last one out due to block casting number. 76/77/79 350. The C7Z I have not seen before. Assuming the rest of it holds true to form, I would guess the 7 is your '77 date, and Z is the Fremont plant, which did assemble GMC trucks.
11-06-2014, 03:47 PM | #13 |
Thanks ka_jd7and1. I was wondering if it might have been a 77 model made in Fremont. It did come from Washington State. Just not sure what the C is for. One site said that it was the check sum character.
Thanks again, JD
04-13-2020, 09:54 AM | #14 |
Way old thread, but gonna add a link.
I have Chevrolet by the Numbers for the cars, but couldn't find detail on the TRUCK engine suffix (XF) decode for my '68 (T0424 XF) Stumbled upon this... The LIME BOOK (FYI, ...downloadable PDF) http://www.camaros.org/pdf/LimeBook.pdf
'68 C20 Utility 396 4sp (BuildThread: http://67-72chevytrucks.com/vboard/s...d.php?t=806904 ) '68 C10 50th |
