06-30-2020, 08:01 PM | #1 |
Drive shaft question
For some reason I cannot use the search feature when I use my phone
So please bear with me. I did a LWB to SWB conversion and the drive shaft is now 12" to long. My question is should I shorten the two piece drive shaft or get a one peice drive shaft made? Thanks |
06-30-2020, 08:12 PM | #2 |
Re: Drive shaft question
I've done both. If I remember correctly you will need to shorten 11 3/8ths to retain the 2 pc. If you can get a one piece, you will never have to fool with the carrier bearing again. A big plus.
:My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=807535 1971 c10 swb/1972 K10 swb/1968 Camaro 350/4spd 1955 210 2 dr sedan/1998 RCSB Z71 |
06-30-2020, 08:13 PM | #3 |
Old member
I would do the 1 piece. I have one in my 71 LWB truck.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
06-30-2020, 11:06 PM | #4 |
You should have shortened the frame in front of the crossmember that the rear control arms fasten to meaning that the driveshaft still pivots on the joint at that point. That in turn means you need to shorten the front half of the driveshaft.
07-01-2020, 09:39 AM | #5 |
I got a 1310 one piece driveshaft off of ebay. Here
That one is for a Th400 yoke. You'll have to measure the length and confirm the yoke you need. I also had to removed the center support hanger. That driveshaft has done fairly well for me even with 500whp. No slicks yet.
-- Josh Instagram: @americanmusc1e OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread 1999 4wd OBS Tahoe - daily. DM me if you can't see photos i posted |
