07-03-2018, 05:43 PM | #1 |
S-10 Drive Shaft Needed
Asking for a friend of mine. He has an '01 S-10 with the 4.3 V-6, automatic trans and extended cab. It has a 2 piece drive shaft and he is needing the rear section. Any one parting out such a truck? Has not been able to find one locally. The Cash for Clunkers and the previous high scrap steel prices sent a lot of parts truck to the melting pots.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
07-17-2018, 10:44 PM | #2 |
Re: S-10 Drive Shaft Needed
the 01 V6 extended cab is a flange pinion mount with a double cardan rear section. thats a real needle in a haystack, and most used units will have the same problem (the double cardan is worn out). I sold just the rear section of one for $150 from a low mileage truck a couple years ago and could have probably asked twice as much with how much my phone rang. you cant easily convert to a one piece because of the crossmember and the proximity of the driveshaft to the floor. plus the length of a one piece can cause problems (harmonics). some guys have converted to the 2wd 4 cylinder ext cab driveshaft which doesnt have the double cardan, but I think you need to change the pinion too and I really have no experience with that swap.
midwest driveshaft http://www.mdsdriveshaft.com/gmc.html sells a replacement with or without the double cardan but its pricey. I have had good luck with driveshaft work at inland truck parts on west k42, their driveshaft guys are great, they call my s10 stuff "toothpicks". dont go in the main door, there is a "driveline shop" door to the left.
07-18-2018, 04:29 PM | #3 |
Thanks for the reply. My friend's problem is the rear section of the drive shaft has a pretty good sized ding (aka dent) in it and is causing an imbalance and a vibration when driving. Being retired and on a small income he is hoping to find something that will work for him from someone parting out a similar S-10. Has not been able to find anything locally.
07-21-2018, 03:06 PM | #4 |
if his double cardan is good, inland can repair (if needed) and rebalance the driveshaft. a cut and balance no u-joints usually runs me $125, so that might be a good guide.
they will probably want the whole thing, and those arent the easiest to pull. best advice I have for removal is to take the axle/sping u bolts out and pull the axle back a few inches. if you dont, the driveshaft will come very close to coming out but wont. doing it this way also makes it easier to separate the flange from the pinion. if you need a yoke for the trans to keep all the fluid in I have one he can borrow. I am just north of wichita. oh one more thing, if he has lowered the truck with blocks, his vibration is likely the center bearing needs shimmed.
07-22-2018, 09:33 AM | #5 |
Thnaks, will pass the info along.
09-10-2018, 03:00 PM | #6 |
Are you still looking for this part?
09-10-2018, 06:42 PM | #7 |
Called and talked to my buddy and he is still looking for a drive shaft. Is your drive shaft complete, both pieces, just the rear section ....? What are you asking for it? Can you post a picture to the board? Communication will be some what slow as he does not have a computer. He is retired on SS so cost of items is a subject for him, hope you understand.
09-17-2018, 11:34 AM | #8 |
I will check this weekend to make sure it is still available and try to get a picture. It is the whole driveshaft. Only cost would be to ship it to you or him. It is used it may need joints etc.
09-17-2018, 03:54 PM | #9 |
That sounds great, please do check if still available and pics are always good. If possible, pics of the u-joint sections would be good. Maybe break it down at the double cardon joint and ship wrapped together in cardboard? Let me know what you come up with. Thanks
09-26-2018, 05:15 AM | #10 |
Any updates on the drive shaft, still available? Still looking for one, thanks.
09-26-2018, 10:00 AM | #11 |
Still available, was not able to get pictures of it yet. Should get there Sunday.
09-26-2018, 12:09 PM | #12 |
Thanks for the up date. Let me know, he is interested for pics, condition and price. Thanks for looking into this.
10-10-2018, 10:01 PM | #13 |
Any progress with the pictures and availability, price, etc.? Thanks,
11-03-2018, 10:54 PM | #14 |
Hi, I have not been on ere in quite some time then could not find the post. I have complete driveshaft in hand. Only cost to you would be shipping. It is out of a 1998 ext cab V6 4L60E from yoke to pinion flange.
11-04-2018, 05:57 PM | #15 |
Hi, spoke with my friend and he is very interested in the drive shaft. Sending a PM your way for added info and questions.
11-20-2018, 01:53 PM | #16 |
Still have Driveshaft but have not heard from anyone about it yet by phone or e-mail.
11-20-2018, 05:17 PM | #17 |
PM sent, thanks for the post reminder.
11-29-2018, 09:44 AM | #18 |
Good info, I am getting ready to scrap a 2001 S-14 and it has the 2 pc driveshaft. I will remove for the future use or future scrap.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T |
01-22-2020, 11:03 AM | #19 |
I still have the Driveshaft, So I will just store it till someone has a use for it.
10-12-2020, 11:11 AM | #20 |
Should this be scrapped or kept?
10-12-2020, 05:54 PM | #21 |
If you have room to store it I think I would keep it around for awhile. Good original parts usually have someone looking for them. Sorry my buddy didn't pick it up from you when he was looking for such. Didn't intend to string you along when I first posted the WTB for him.
10-12-2020, 06:23 PM | #22 |
That's Ok, You and I were both just trying to help someone in need.
