Old 12-15-2015, 03:55 PM   #1
NVS-C10
NVS-C10's Avatar
My 63 SWB BBW Build Frank
So since I'm done (for now) with my 63 Stepper "EZ Eight" and my 70 C10 is now a citizen of Australia I decided to pull my 63 SWB BBW project out (aka Frank) and finish him up...
Here's Frank sitting next to EZ Eight and starting to get piled in...
And here's my former 70 C10 that now resides in Australia
NVS-C10 is offline   Reply With Quote
Old 12-15-2015, 03:56 PM   #2
NVS-C10
NVS-C10's Avatar
Re: My 63 SWB BBW Build Frank
So got Frank out and have another project to keep EZ Eight company lol...
Old 12-15-2015, 04:11 PM   #3
NVS-C10
NVS-C10's Avatar
So now that Frank is in a place where I can work on him, I dusted him off and checked out where I left off and what's next on the list. I also installed some freshly powder coated stockers and new rubber.
I had already finished most the front suspension and my next steps should be rear suspension then the 283/Powerglide drive train.
Old 12-15-2015, 05:20 PM   #4
Bomp
Bomp's Avatar
Looks good, I'll follow along.
Bomp is offline   Reply With Quote
Old 12-15-2015, 09:19 PM   #5
NVS-C10
NVS-C10's Avatar
Thanks.. I been watching both your builds but "C10 Dually with a lilttle C60 flavor tossed in" is my FAVORITE!!!
Old 12-16-2015, 02:20 PM   #6
TJ's Chevy
TJ's Chevy's Avatar
In for the build. Frank is a good looking truck!
Old 12-16-2015, 02:46 PM   #7
Grizz1963
Grizz1963's Avatar
I do like the EZ-Eight truck.
If it and the Australian are anything to go by..... Frank will Frankly be terrific.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is online now   Reply With Quote
Old 12-21-2015, 07:42 PM   #8
NVS-C10
NVS-C10's Avatar
OK some updates...
Got my CPP notches in (you can see the template I made on the floor in the background:
Shipping was free and super-fast (1-day), fitment was spot on, and the only hard part of the job I could say was getting out (fighting lol) the factory rivets
Old 12-21-2015, 07:47 PM   #9
NVS-C10
NVS-C10's Avatar
Next was on to the rear shock relocation brackets...
Old 12-21-2015, 07:54 PM   #10
NVS-C10
NVS-C10's Avatar
Drill and bolt in...
They line up good with the frame and fit nice next to the CPP notches... you can also see the CPP Deluxe Trac Bar installed with 2" CPP Drop Blocks.
Old 12-21-2015, 07:59 PM   #11
NVS-C10
NVS-C10's Avatar
I'm using the factory bottom rear shock mounts just flipped around and swapped sides...
Frame clearance is good...
Here is the hardware for the top shock mount to bracket...
Old 12-21-2015, 08:02 PM   #12
NVS-C10
NVS-C10's Avatar
Best part is the shock angle looks really good so they should function the best they can...
Old 12-21-2015, 09:18 PM   #13
TJ's Chevy
TJ's Chevy's Avatar
Looks good!
Old 12-21-2015, 09:51 PM   #14
NVS-C10
NVS-C10's Avatar
Originally Posted by TJ's Chevy View Post
Looks good!
Thanks!!!
Next week Engine and Trans should be going in... SBC 350 (Dressed as a 283) with Powerglide Trans.. will be using factory V8 mounts and CPP tubular trans cross member.
Old 01-05-2016, 08:40 PM   #15
NVS-C10
NVS-C10's Avatar
Well I worked on a few different items but kind of bounced back and forth between; not fully finishing any one item.
I got the engine and trans in but still need to bolt on some more items and then will post pics. I also started on the bed floor but wasn't able to finish with the holidays.. will post pics when complete.
So not to leave you without any pics; here's one I took on Sunday of the rear sitting a hair above driving height. The front is static drop and the rear will be bagged (currently the rear is blocked up to estimated ride height).
Old 01-07-2016, 12:48 AM   #16
NevEno
NevEno's Avatar
Nice!!
You can find me on Instagram @neveno_cten
NevEno is offline   Reply With Quote
Old 01-07-2016, 08:49 AM   #17
clemdaddy
clemdaddy's Avatar
subscribed… really like where you and Frank are going.
clemdaddy is offline   Reply With Quote
Old 01-07-2016, 01:42 PM   #18
NVS-C10
NVS-C10's Avatar
Originally Posted by NevEno View Post
Nice!!
Thanks!!
Been checking out your 64 build for a while.. love your wheels/tire/hubcap setup and the C10 tailgate you did that ended up on your daughters bed.. gonna have to do something like that for my daughter when she's bigger
Old 01-07-2016, 01:42 PM   #19
NVS-C10
NVS-C10's Avatar
Thanks!!
Old 01-07-2016, 07:20 PM   #20
NevEno
NevEno's Avatar
Originally Posted by NVS-C10 View Post
Thanks!!
Thanks!! Do it they are only young once!!
Old 01-07-2016, 10:56 PM   #21
NVS-C10
NVS-C10's Avatar
Trust me I know and I'm starting her out as young as I can.. she works on EZ Eight while I'm working on Frank lol
Old 02-08-2016, 03:04 PM   #22
NVS-C10
NVS-C10's Avatar
Been a few weeks since I updated but still been working on Frank..
Got 2/3's of the bed done.. will finish back half after I get my tank and compressor mounted (its going under that part of the bed).
Old 02-08-2016, 03:08 PM   #23
NVS-C10
NVS-C10's Avatar
Got motor and trans in..
I used the CPP Trans crossmember and it worked great with my Powerglide; and I can use the same crossmember and mount if I want to upgrade to 700R4 later on.
Old 02-08-2016, 03:12 PM   #24
NVS-C10
NVS-C10's Avatar
Also since this chassis was originally fitted with a 3-Speed Manual Trans, I had to find an original Powerglide frame pivot bracket (that was a search lol).
I setup the starter for a remote starter solenoid and added a large 4-gauge ground strap for increased engine and starter grounding.
Old 02-08-2016, 03:16 PM   #25
NVS-C10
NVS-C10's Avatar
Lastly I cleaned up the cab for installation next weekend!!!! Can't wait!
