Old 12-09-2023, 10:54 PM   #251
dsraven
Re: '50 3600 re-do. Shortening things up!
well, at least you know now.
Old 01-07-2024, 05:00 PM   #252
mobileortho
mobileortho's Avatar
I was off all week and had plans to spend as much time as I could working on the truck. In the end, I was only able to hook up the fuel filler and mount the tail lights. I changed course on lights in the roll pan and installed stock styled LED’s.
Robert C.
1950 3600
3600 re-do, shortening it up
If it's true what they say, "You learn from your mistakes,"
I'm a Genius in the making.
mobileortho is offline   Reply With Quote
Old 01-16-2024, 11:03 PM   #253
mobileortho
Originally Posted by joedoh View Post
oof thats a mess for sure!
Not perfect but much improved!
Robert C.
1950 3600
Old 01-22-2024, 10:19 AM   #254
mobileortho
I've been scratching my head trying to figure out where the puddle of brake fluid was coming from on the drivers side around the front wheel. All the lines were checked & double checked & after closer inspection it appeared that it was coming from somewhere around the master cylinder so I set up me camera to see what happened when I applied the brakes and was shocked to see that the pressure switch on the proportioning valve was gushing fluid, not from the threaded connection but from around the front section by the plug. Somewhat surprised that this would fail especially since it's new.
Robert C.
1950 3600
Old 01-22-2024, 10:39 AM   #255
dsraven
sometimes being new can be worse than using the old part, lol.
Old 01-22-2024, 10:51 AM   #256
mobileortho
True! I wasn't using it anyway, so I just capped it off.
Robert C.
1950 3600
Old 03-24-2024, 06:35 PM   #257
mobileortho
Added a set of LED headlights. These have built in DRLs & turn signals. Can't figure out what the emergency flashers don't work though. I Hope to be able to test drive this thing soon!
Robert C.
1950 3600
